margkerberg
Hi, I would like to suggest an advanced solution that I have used in the past. It helps you a lot to export NSF for PST in fast time with no information loss. Convert for NSF file to PST helps to retrieve mailbox data and convert into Outlook PST. In Recovery Process Software recover NSF email, contacts, calendar, tasks, notes, inbox items, outbox items, and appointments. In addition, ATS Lotus Notes Conversion software provides several conversion formats for Lotus Note files such as - PST, EML, MSG, HTML, EMLX, MBOX, CSV, Office365 & live Exchange Server with ICS, and vCard to name.nsf file without creating any problem. Convert to format. With the free version of the software, you will get the freedom to export 25 emails in each folder in every file format. This Lotus Note application supports versions 10.1, 9.1 and below and MS Outlook 2019, 2016 and its lower versions.
Few Step to save Lotus Notes to PST
  • Open Lotus Notes NSF file into ATS NSF To PST Converter tool.
  • Convert NSF file into PST file to click Export then Select the PST option.
  • After Select then Click browse to save PST.
  • Click Office365 &Exchange option to save the NSF file to Cloud Server.
Download Software: ATS For NSF to PST Converter
piteralexie
Here, is an advanced utility that is provided by the brand eSoftTools name as the NSF to PST Converter Software, that has the power to smartly remove all errors from the NSF file and it easily exports all its internal items to multiple file format PST, EML, EMLX, MSG, HTML, VCF, CSV, MBOX, and ICS. It is compatible with all versions of Lotus Notes and MS Outlook (up to 2019) means it can convert the NSF file of any version of IBM Lotus notes to PST.
Get More Info:- https://www.esofttools.com/nsf-to-pst-converter.html
