autonuke with 10 passes?
boostman
I'm wondering if it is possible to configue DBAN to do 10 passes with the "autonuke" feature?
I've just started looking into this so thought I would post as I researched to see if someone knows already.
Thanks
Yes, but you want to change the "rounds", not the "passes". Edit the A:\SYSLINUX.CFG file or search this forum for information about remastering the ISO file.
boostman
Thanks for the reply, will do. I had found similar information pointing to the SYSLINUX.CFG
