ethanbrowns
InQuit EDB to PST converter application is the best program provides facility to convert required folders from priv 1.edb file and pub 1.edb file included with email, notes, task, attachment, contact, draft, inbox, and calendar (To, Cc, From, Date, Time, Subject, Object and Bcc).
This conversion tool easily recovers data from damaged EDB file and convert them into a new Outlook PST file format without any difficulty. This application allows you to view all the data of EDB file before conversion in its preview facility.
Through the aid of this Exchange EDB to PST program, you can export your password protected and encrypted data file in a safe manner without any difficulty. This application has a split facility that allows splitting the big file into several small files as per the user’s requirement.
The users save their data into several interesting file formats like PST, EML, MSG, MBOX, HTML, vCard, vCal, and EMLX.
If you are not happy with its work then you can return under 30 days without any difficulty. It is very simple to use.
Read more: InQuit EDB to PST Converter
