You can easily and safely migrate Offline OST files to PST file format by using OST to PST Exporter utility within a few seconds. This migration software is able to export all OST mailbox item like contacts, calendars, inbox, outbox, zip attachments, appointment, tasks entries, journals, user created folders etc.
* It works on OST file versions-2003, 2007, 2010, 2013, 2016. 2019.
* It works with all Windows OS version like: XP, Vista, 7, 8.1 and 10.
* Compatible with entire MS Outlook (32 and 64bits) version.
More info visit here:- https://www.datavare.com/software/ost-to-pst-converter-expert.html
ATS OST to PST converter is a useful application which helps you to repair and recover corrupt OST files. The OST to PST Converter tool allow recovery as well as the conversation of OST to Outlook PST file. Export OST file to PST efficiently supports any versions of MS Outlook office-365, 2016 and all Lower version. This program is capable to access permanently deleted OST file safely and secularly with all items of the mailbox. Using this utility you will remove corruption issues of OST files and easily export OST file into various formats PST, EML, MSG, HTML, EMLX, MBOX, vCal, vCard, Office 365 & live Exchange Server.
If anyone wants an easy solution for OST to PST conversion and searching best OST to PST converter tool. Try the most reliable and fast conversion tool, Shoviv OST to PST Converter. The tool converts OST data to PST proficiently, recovers the permanently deleted items, and repair corrupted OST files. It exports single as well as multiple OST data into Outlook PST, Live Exchange Server, and Office 365 in a single attempt. It also exports OST data into EML, MSG, RTF, vCard, and HTML formats. The tool supports all versions of Outlook and Windows OS. Download its free trial version to check all the features and functionality. The demo version also capable to convert the first 25 items per folder.
More details, visit:-
https://gallery.technet.microsoft.com/OST-to-PST-converter-c8add6e2
eSoftTools introduces the best OST to PST Converter software to recover and convert damaged OST file into multiple formats like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. It securely converts the OST file without losing the data of other existing files of the database, for the secure conversion a smart preview is shown to the user to check and confirm the file format. It does not require installation of MS Outlook for the conversion and recovery of OST file into other formats. A FREE DEMO version is available of this tool, easily up to 50 emails can be converted into all formats.
Get more info:- Converts OST to PST
jamesband
The migration of the data from OST file format to PST format is can be done by Best OST to PST Converter Software which will provide a safe and accurate solution for the data conversion. It allows the use to transfer the data properly from any size of OST file to PST format with any problem.
ruchika
I would like to suggest you Ignissta OST Converter software which is best OST to PST Converter software. This software provide Best OST to PST Conversion results without any data loss.
  1. No File size limitations, Convert Unlimited OST to PST file with Ease
  2. Capable to convert Multiple file format like OST to PST, OST to Office 365, OST to Vcard, OST to Mbox, OST to EML and OST to MSG
Download Trail Version which provide ost to pst conversion features with first 50 items per folder download now https://www.ignissta.com/ost-to-pst-converter/
camilia
Search a master solution & unique technology "Outlook OST to PST" Conversion software which recover inaccessible files of Outlook offline OST with save all Emails properties easily. It fastly works to convert with save all database from damage offline OST file into Outlook formats-: Gmail, Drive, Zimbra, office 635, Live Exchange, MBOX, vCard, vCal MSG etc. More info-: https://www.kdetools.com/converter/osttopst/
jackbryan
Get the best conversion of OST file by using the reliable and best OST to PST Converter Tool of eSoftTools, by this program you can easily convert OST file into 6+ multiple formats like HTML, PST Outlook, CSV, EML, MSG, Office 365, MBOX and vCard.
It does not require installation of Outlook for converting OST file into PST Outlook and works smoothly with all file versions of Outlook such as: 2000, 2003, 2007, 2010, 2013, 2016, 2019.
Explore more info:- Convert OST to PST
beckerjaxson54
If you are facing this issue and want to find a solution, then I will suggest you try Mac OST to PST Converter this software will help you to migrate emails from OST file to PST file extension. You can download this software from here Mac OST to PST Converter. The software supports all Mac OS versions like 10.10, 10.11, 10.12, 10.13, 10.14.
Visit here:- https://www.toolscrunch.com/mac-ost-to-pst-converter.html
