Best OST to PST Converter Third Party Tool
A lot of third-party software are available in the data recovery industry but it is really hard to choose the best one, here is the solution to get back your damaged OST files and save them into most recommendable PST format which is easily accessible and readable in any Outlook version. This OST to PST Recovery tool from SysOZ software also allows you to keep you converted the result in different formats such as PST, EML, EMLX, vCard, vCal, MSG, and MBOX.
SysOZ OST to PST Converter have following features:
Display preview of the recovered mailbox: Before the actual conversion it displays the preview of recovered mailbox along with email, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes etc.
24x7 support: If you have any problem or question and query then you can contact our experts who are available 24x7 hour.
MS Outlook installation is not compulsory:
The installation of MS Outlook on the system is not necessary to convert OST data into PST.
Support Office365& live Exchange Server:
It has an additional function that is cloud-based application Office365 & Live Exchange Server.
Various format are supported by this tool:
You can easily convert your data into various formats like PST, EML, EMLX, vCard, vCal, MSG, and MBOX.
OST to PST Migration software is the perfect solution for converting unlimited OST files to PST file without any trouble. You can use this application to get error-free results. Various advance options of the tool make your conversion simple and smooth. The tool works on all Windows versions. The software gives users flexibility to convert data of any outlook version.
More info visit here;- https://www.datavare.com/software/ost-to-pst-converter-expert.html
jamesband
OST to PST Converter software is a prominent application that migrate OST to PST with all emails and attachments. The program is highly designed with advanced features and simplicity so that non-technical users can easily operate it. There is no file size limitation to transfer OST to PST format. All OST and PST versions are well supported by the software.
ruchika
If you want to convert OST file to PST file you must need to install OST Converter Software which provide 100% safe and secure conversion. I would like to suggest Ignissta OST Converter Software which helps to repair and recover OST file and convert to PST file with 100% data accuracy.
  1. No File Size Limitations, convert unlimited and large OST file without file size limitations
  2. No Need to install Outlook While OST to PST file conversion
  3. Capable to convert multiple file format such as OST to PST, Office 365, Vcard, EML, MSG and MBOX
  4. Provide 100% safe and secure conversion results with 200% Data Accuracy
  5. Split option also there to convert large OST file to Small Size of PST file
Download Now OST Converter and Convert OST to PST file with Ease https://www.ignissta.com/ost-to-pst-converter/
Simple and Easy Conversion Process
Browse OST file ----------->
Preview Mail Items -------------> Export to PST File
OST to PST Converter application helps users for conversion selective single and multiple OST folders and restore with emails, contacts, calendars, task, notes, inbox items, outbox items, and supports all MS Outlook versions 2000, 2003, 2007, 2010, 2013 and 2016. This utility tested on the large size of Outlook OST file database in the laboratory. You can directly migrate data into Live Exchange server and Office 365.
Read More: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
piteralexie
Get this best third party software named as the eSoftTools OST to PST Converter software to convert the offline OST file into Outlook PST file format. By using this tool user will get the ability to export all emails, contacts, calendars, tasks, journals, reminders, and other items from a corrupt OST file into a new PST file without making any changes.
Get more information about the tool and download it from here: https://www.esofttools.com/ost-to-pst-converter.html
