Best OST to PST Converter
Standard Features of InQuit OST to PST:
Scanning Process:
its auto scanning facility is amazing which fetch all kind of problems and remove them instantly without consuming more time.
Export single and multiple files: With the help of InQuit OST to PST software you can export single as well as multiple files in a few minutes.
Show the preview: Before finishing the conversion it shows the preview of recovered mailbox along with emails, contacts, inbox, drafts, calendars, deleted-items, sent items, outbox, notes.
Splitting Large File: if the user has large OST file so it split it into several small PST files as per their need.
Saving formats: After the conversion, you can preserve the data into several interesting file formats like PST, EML, MSG, vCal, vCard, EMLX, MBOX and HTML.
Demo Facility: the free demo version of this tool allows you to extract 30 email items per folder free of cost.
Read More: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
ruchika
Ignissta OST to PST Converter is Best Software which helps to repair and recover Corrupted OST file and Convert to PST file. After conversion you can access all Mails Data in Outlook.
  1. No File Size Limitations, Convert Unlimited OST File to PST File
  2. Capable to Convert Multiple File format, OST to PST, OST to Office 365, OST to EML, OST to Vcard, OST to MSG
  3. Supported all MS Outlook Version 2019, 2016, 2013, 2010 and 2007
  4. Provide safe and secure conversion results with 100% data accuracy
Download Trail Version and Convert OST to PST File https://www.ignissta.com/ost-to-pst-converter/
Easy and Simple Process
1. Browse and Select OST File -------> 2. Preview Mail Items ------> 3. Export to PST Files
margkerberg
Are you searching for a Best OST to PST Converter utility to retrieve Exchange OST mailbox data and convert/migrate OST files into PST format without any hassle? Is it so, then you need to go for any third-party tool to convert ost to pst solutions. First, I will make you ensure that it is available only a healthy OST file or Connected Outlook file for a manual solution that is available to save emails into PST format. There are lots of third-party tools are available in the market, then you need to select the right one.
I would suggest you can try one of the best & trusted conversion tool i.e. ATS OST to PST Converter. It is a straightforward solution for users to easily & 100% Safely export OST to PST with attachments. It allows you to transfer emails from OST file into PST format along with emails, attachments, contacts, tasks, etc. Users just need to follow simple steps.
  • Download ATS OST to PST Converter Software Click here.
  • Install Software and select Curropted OST File.
  • See Preview recover mailbox mails item message with meta tag( To, Bcc, Cc, from, subject, attachment & date etc.).
  • Click on the Export button to save recover OST mailbox data into Outlook PST, MSG, EML, EMLX, MBOX, vCal, vCard, HTML and PDF file type.
  • The split option is also available to split large file data into small PST files.
  • This Software has the ability for users to direct export offline OST file data into Cloud applications like Office365, web-based, Outlook.com & Exchange Server.
Hi, I am sharing information for retrieve OST file mailbox data, Download a Best OST to PST Converter tool to repair & recover OST file data such as email, Contacts, Calendars, and attachment etc and convert into Outlook PST file formats. This software support all Outlook version including 2019 and exchange Server 2016. This software also allow for Outlook users, if you want to export offline OST file into Cloud application office365 & live Exchange Server.
Read more: https://www.vartikasoftware.com/product/vs-ost-to-pst-converter-software.html
jamesband
OST to PST Converter software is an flawless solution to migrate OST mailbox to MS Outlook PST. The utility performs OST to PST migration in a very easily to use. It migrates all OST emails items like contact, calendars, tasks, journals, notes, emails properties and attachments to PST format, This utility is compatible with Windows versions 95/NT/ 98/2000/ XP/ Vista/7/8/8.1/ 10 and MS Outlook 2000, XP, 2003, 2007, 2010, 2013, 2016.
