Best Solution to Convert OST to PST
camilia
Try the amazing solution to export corrupt offline OST to PST that designed by to save OST to PST with maintaining all the email properties (like To, Bcc, from, size, subject, date, and time). I am talking about the best OST to PST Converter which facilitates the user to convert multiple emails/mails data from offline OST to Outlook PST at once. This software 100% supports to give a live preview of all the internal items of Outlook OST file which you want to convert before starting the conversion of ( PST, Gmail, Drive, Zimbra, office 365, Live Exchange, MSG,( Contacts, Calendar)vCard/vCal, EML/EMLX, MBOX, HTML etc.
Read More-:
https://www.kdetools.com/ost-to-pst-converter.html
OST to PST Converter for Mac Tool this software easily to transfer OST database to Outlook PST file format. It also recovers OST file data along with whole corrupted Outlook OST email items such as - Inbox, outbox, sent mail, note, task, journals, and draft, etc. By using this application, you can also save OST data as PST File format. It also works on all MS Outlook versions like 2007, 2010, 2013, 2016 and 2019. This software supports all Mac OS versions like:- 10.13, 10.12, 10.11, 10.10.
If you have OST files whom you want to migrate to Outlook email client. It has all benefits that a user looks for such as it is supportive to run on all Windows operating systems and having an easy interface, users do not require technical skills to handle the program. It does not matter which email application OST file you have, the software is compatible to transfer all OST based clients file. Softaken OST to PST Converter application scans the converted PST file on all versions of Microsoft Outlook – Outlook 2003, 2007, 2010, 2013 and above versions.
