Conversion from NSF to PST Outlook 2019
By taking the assistance of NSF to PST Converter application users can easily convert NSF data into PST data along with email, draft, task, attachment, notes, contact, sent item, journals etc. It is compatible to export NSF data into PST in the absence of MS Outlook installation. This is a very secure way for the conversion purpose.
The Admirable Features
  • Easily export NSF data into PST file.
  • Display preview of recovered mailbox before the conversion.
  • Export one as well as more than one file.
  • Support all version of OS Windows-like95, 98, Win NT, Win ME, Win XP, Win Vista, Win7, Win 8, Win 8.1, and Win 10.
  • Easily export Lotus Notes data into Outlook PST along with email, draft, task, attachment, notes, contact, sent item, delete item and many more.
  • Save the resultant file into PST, EML, EMLX, MSG, vCal, vCard, CSV, MBOX file formats as per your need.
  • It backing Office365 & live Exchange Server.
  • It backing Lotus Notes version9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5, 6.0 and, 5.0.
  • Gives 30 days money back guarantee.
Read More Info: https://www.inquitsoftware.com/en/nsf-to-pst-converter.html
If you want to convert Lotus Notes NSF to PST Outlook, So Shoviv Lotus Notes to Outlook Converter software is another effective solution to migrate your NSF files to PST without any interruption. It migrates unlimited mailboxes from Lotus Notes NSF to PST Outlook, EML, and MSG in a single attempt. It supports all the Microsoft Windows Operating systems and Outlook versions. It provides the free trial version of this tool which helps you can convert the first 25 items per folders.
More Details, visit:-
Migrate from IBM Lotus Notes to Microsoft Outlook by converting NSF file into PST format using NSF to PST Converter. You can use this tool to convert NSF file to PST and also directly export to Office 365 or Exchange Server. This NSF Converter Software supports NSF file from Lotus Notes versions 10.0.1, 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0.
jamesband
I would suggest you easy way to convert NSF file to PST file formats without any loss of data. This NSF File to Outlook Converter tool is really very useful for Converting NSF file data as Outlook PST file formats. If you are not in a technical knowledge based personality yet you can easily convert NSF file into PST file without facing any kind of problems. this tool has the ability to convert NSF files into PST files so the users can use it anywhere and in any device which support MS Outlook.
More Info :- NSF File to Outlook Converter
