Convert an OST to a PST in Outlook 2016
ralphmiller
If you are using MS Outlook and want to convert your emails, contacts, calendar items etc from OST to PST file, then I recommend you to try vMail OST to PST Converter.
Key features:
  • Convert OST to PST, MBOX, MSG, EML, EMLX, vCard and vCal formats
  • Recover all Inbox, Outbox, Sent Items, Drafts, Deleted Items, Contacts, Calendar, Tasks, Notes, Journals etc.
  • Supports large size of OST file.
  • Export option directly to Office 365 & Exchange Server.
  • Compatible with Microsoft Outlook 2016, 2013, 2010, 2007 & more versions.
Download vMail OST to PST Converter
eSoftTools OST to PST Converter instrument is one of the first class programming programs present in the online area for reclamation of degenerate OST records. for the time being the change office is only an additional advantage with this. despite the fact that back-end of the device to send out OST to PST is packed with mechanical offices however it doesn't consider the operational end.
Read more:-
http://ostrecoverysoftware.over-blog.com/2018/10/ost-to-pst-converter-software.html
OST to PST Converter tool to recover corrupt files very easily and convert OST email into EML, MSG, PST and HTML formats. OST converter is easy way to conversion of OST files into PST files. OST to PST software fruitfully carry all version of MS Outlook podium.
Vartika OST to PST Converter is mind blowing application to convert OST mailbox items into several formats such as- PST, Office 365, Live Exchange Server, EML, MSG, HTML and MBOX with all email properties (To, Cc, Bcc, Date, Time and Subject etc.). You can use different features of this application as per your need. This application is applicable on all windows versions up to 10 and MS Outlook versions up to 2016 (32 & 64 Bit).
Get Software- Convert OST to PST
Convert an OST file to PST in Outlook 2016 using Perfect Data Solutions OST to PST Converter. I am recommending this software because it widely used and gives accurate result at the time of conversion of OST to PST. This software is capable to convert heavy size of OST file to PST, EML, Office 365, MSG, HTML, PDF and MBOX.
Convert OST to PST
Tried converting your OST data but still do not get the best outcome? Here is one of the best tools available to convert your OST files to PST file format or in any other formats as per your need. Name of the tool to convert your OST to PST format is InQuit OST Converter. This software is supportable with MS Outlook version 98, 2000, 2002, 2007, 2010, 2013, 2016 and 2019. With the help of this software you can easily split your large OST files into various PST files. Free demo for the InQuit OST Converter is also available.
Read more: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
alex786
To convert OST to PST in Outlook 2016 and other versions, I would recommend you to make use of Shoviv OST to PST Converter software. With the help of this tool, users can repair severely corrupted OST files, restore deleted items and export OST to PST, Office 365, and Live Exchange server. It also lets users download a free trial version so that one can check its features and working process.
Read More: www.shoviv.com/ost-to-pst-converter.html
Hi
I recommend you to go for third party tools because there is no any freeware solution in google.
Uou can try one of the best KDETools OST to PST converter tool as this will surely help you out to Convert large OST file to PST for Outlook 2019, 2016, 2013, 2010, 2007, 20003 etc
Hope this solution helps to resolve your problem.
