Convert OLM to PST
crickwilli
Convert OLM to PST file format install an effective tool Kernel for OLM to PST Converter Tool. This tool easy to converts whole OLM file components such as mails, attachments, contacts and calendar events to PST format. OLM to PST tool is more compatible with Windows 10 and Office 365. It supports all versions of MS Outlook and all updated Windows OS versions.
Vernon Philander
With OLM to PST Converter Tool, you can efficiently keep corruption, errors and inaccessibility issues with OLM files at bay. Including hyperlinks, attachments, contacts, calendars, it repairs and restores all of your severely damaged or permanently damaged emails back and saves all these recovered items in accessible PST data file. In Windows environment, you can easily access them with MS Outlook. Free Trial Version Available - http://www.olm-to-pst.recoverydeletedfiles.com/
Michael Trailer
There is no better method to move Mac Outlook data to its Windows variant than using “OLM to PST Converter Ultimate.” It’s a tool that eliminates all the troubles of regular OLM to PST conversion by directly converting from Outlook identities. You are finally ridden of the trouble of using OLM files. Moreover, the tool is built keeping the regular users’ skillset in mind. So the GUI is incredibly basic and minimalistic. You can start converting your data within a minute with no prior learning or experience. For the first time, email migration between these two clients will be a smooth sail, something that never was possible with any other OLM to PST converters. So why wait? Download the free trial version now!
Christian Stewart
Download OLM to PST Free Setup
Now use this very easy to use and simple interface OLM Converter tool that allows to export OLM files to Outlook PST, Office 365 directly. The tool provides separate option to convert OLM contacts to Outlook contcts & OLM calendars to ICS files.
Sophia
One can use OLM to PST Converter to migrate emails from Mac Outlook to Windows Outlook. By converting mac olm file to pst format user can access olm file on Windows also. It supports to all Outlook versions such as 2016, 2013, 2010, 2007 etc.
Before you can purchase any paid software for OLM to PST conversion, you should try an easy manual trick. The manual trick will help you import mailbox content from Mac Outlook to Windows Outlook without requiring any 3rd party paid software.
  • First, create an IMAP mail account first.
  • Now set up this new IMAP mail account with Outlook for Mac.
  • Create a Gmail label to synchronize IMAP mailbox folder with Outlook for Mac.
  • Now transfer mailbox content from OLM files to IMAP mailbox folder.
  • Finally, move IMAP mailbox folder data to Windows Outlook.
You can read this post for more information: Convert OLM to PST Manually - An Easy Step-by-Step Guide
C Phillips
Hi,
For OLM file conversion in PST file, it is better to try a manual method before switching to any third party solution. In the manual method, You need to configure a Gmail IMAP account in both Windows Outlook and Mac Outlook. On the other hand, It is quite technical and time confusing process. So, third party utility is the best option to convert olm file in PST format. So, You should try QuickData OLM to PST Converter.
Thanks
mackjohn
I trust on OLM to PST Converter Software because It worked well for me. I easily converted Mac Outlook OLM files and imported in Windows Outlook. The software GUI is quite easy and helpful. Within few clicks, you can convert your entire data. Just download and install the utility in any windows os environment.
smithjake
OLM to PST converter tool is an email migration software which quickly restores MS Outlook data from Mac Outlook to MS Outlook. It retrieves all mailbox data from OLM files of Outlook for Mac and exports them to Outlook PST file. OLM to PST tool maintains original formatting, properties and structure of Outlook for Mac emails in the new mailbox. See more at: https://softcart.wordpress.com/olm-to-pst-converter-software/
mcclarke
An export MAC Outlook 2011 OLM file of all Outlook, Windows versions, I would suggest an effective OLM to PST Converter software. The tool quickly & safely converts all email items including email, calendar, attachment, contact, etc. It's more compatible with Windows 10 and Office 365. After conversion the software saved different file formats like PST, MSG, EML, MBOX, IMAP, RTF, TXT, MHTML, HTML and etc. It supports all versions of MS Outlook 97, 98, 2000, 2002 2003, 2007, 2010, 2013 and 2016 and all updated Windows OS versions. To know more detail click here -
http://www.olmtooutlookpst.com
To export email files from Outlook for Mac to outlook on Windows pc you just need to convert .olm files from outlook to .pst file. PST files are compatible with outlook & other editions of outlook running on windows. You may try OLM to PST Converter for Mac.
If you are using Windows PC and want to convert Mac OLM files into MS Outlook in Windows Operating System then you can try this utility in which convert your data from OLM to PST format instantly without making any trouble. You must try its trial version which is free of cost, download OLM to PST Converter for Windows.
hopemarha
Softaken OLM to PST Converter software which can easily export all emails of OLM, files, folders, into Outlook PST format. You can use this software for converting OLm to PST file. This can also export several OLM files to MS Outlook in a single conversion cycle. This software quickly retrieves mails, contacts, calendar items, attached files and other data from OLM files.
If you want to convert OLM to PST file format, you can use ToolsGround OLM to PST Converter For Windows. The tool easy to convert all email items such as emails, attachments, contacts, calendar, and account information, etc. I would like to this software for windows It allows the user to convert OLM files into Outlook PST Format.
More info;- https://www.toolsground.com/olm-to-pst-converter/
