camilia
If you want to Convert Orphaned OST to PST Outlook then, All Users can Try KDETools for OST to PST Migration tool that provides multiple feature facilities to transfer data from OST to PST Outlook directly. The Software is a well solution for fix files of OST and also easily converts all the OST data such as- emails, contacts, tasks, calendars, notes, etc. to Outlook PST format.
- Add- File/Folder.
- Split Option.
- Message Filtering: This option allows you to export OST items as per given date range.
- Folder Selection: You can also select/ deselect OST folders from the left pane of the software. This option helps you to export only required folder(s).
