Convert OST to PST in a couple of clicks
Taking the help of OST to PST Converter users can easily export their entire data of OST file into Outlook PST file format included with emails, notes, attachment, draft, task, sent item, delete item, journals, contact, and inbox etc. It is a very safe and secure way for the conversion work. Before the conversion work of OST data into Outlook PST data users can see preview of recovered mailbox with full ease. During the conversion it keeps the originality of Metadata like To, Cc, From, Date, Time, Subject, Object and Bcc.
The Best Features
  • You can export your corrupt data into new PST data and other PST, EML, MSG, MBOX and HTML file format.
  • Tested on the very large size of Outlook OST file in the software database laboratory.
  • You can save your OST data into office 365& Exchange server.
  • It supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016.
  • You can safely convert multiple large OST files to PST without any change or losing data.
  • It gives 24x7 technical support.
  • This application gives 100% correct result after the conversion process.
Read More Info: https://ofllineosttopst.blogspot.com/2019/02/offline-ost-to-outlook-pst-conversion.html
Use outstanding OST to PST Converter developed by Perfect Data Solutions and convert OST file to PST in a couple of clicks. This software has capacity to convert huge size of OST file to PST/ Office365/ MSG/ EML/ PDF/ MBOX and HTML with all folders & sub-folders. This software works with MS Outlook versions up to 2019 (32-64 Bit).
Convert OST to PST
