Create backups of AOL accounts
devin
For the backup of AOL account you can try AOL backup tool they help to create the backup of your AOL account they backup your account in a few steps like.
The first step is to install and run software
Second, AOL username and password is required for connecting to your AOL account therefor
The third step is to select those mail you want to backup
The last step is a select export option (EML, EMLX, MSG, MBOX, PST) file format that as per requirement and the export data accessed to any version of outlook, apple mail, window live mail and other client and select output directory where do you want to save and then click process now button . For more detail use this link: http://www.osttopstapp.com/aol-backup.html
