directly export OST emails in PST and Office365
The users can directly export their data into Office365 & Live Exchange Server. Don't go with the manual method to convert OST data into PST data file because it is very tricky and technical. Therefore, I would like to inform about OST to PST Converter that is created by SysOZ team. Graphical User Interface of this utility makes the conversion smooth and reliable. With the aid of this conversion software, users can export email, draft, task, attachment, notes, journals, inbox, sent item, delete item and calendar etc. from OST file to PST file format. You can also convert your data into various formats like PST, EML, EMLX, MSG, vCal, vCard and MBOX.
ruchika
Ignissta OST to PST Converter is Best Software which helps to repair and recover Corrupted OST file and Convert to PST file. After conversion you can access all Mails Data in Outlook.
Important Features for OST Converter
  1. No File Size Limitations, Convert Unlimited OST File to PST File
  2. Capable to Convert Multiple File format, OST to PST, OST to Office 365, OST to EML, OST to Vcard, OST to MSG
  3. Supported all MS Outlook Version 2019, 2016, 2013, 2010 and 2007
  4. Provide safe and secure conversion results with 100% data accuracy
Download Trail Version and Convert OST to PST File https://www.ignissta.com/ost-to-pst-converter/
Easy and Simple Process
1. Browse and Select OST File ------->
2. Preview Mail Items ------> 3. Export to PST Files
jamesband
The OST file and PST file supports in MS Outlook but if you want to know how to migrate the data from OST to PST then you can try the OST to PST Converter tool. This is a windows application to move the data from OST to PST file format quickly and make user problem solved instantly. This utility also provide a free trial version which you can try from here:- https://www.softaken.com/ost-to-pst-converter
