Easy Perform with OLM Recovery Tool
Laura Marsh
In addition to OLM Data Recovery ,which is very helpful for those who wants to migrate data from Mac Outlook to Windows Outlook PST file format.It also convert OLM file to PST format with all email components, such as Inbox, Contacts, Calendars, Tasks, and Notes etc. The software is multi-functional as it will fix your corrupted OLM file and save the recovered data into a new PST and other files like MSG, EML and MBOX format.
Get more details and download free demo version, here: – http://www.olmrecovery.recoverfilesdata.com/
Before you can purchase any paid software for OLM to PST conversion, you should try an easy manual trick that requires no 3rd party tool.
  • First, create an IMAP mail account first.
  • Now set up this new IMAP mail account with Outlook for Mac.
  • Create a Gmail label to synchronize IMAP mailbox folder with Outlook for Mac.
  • Transfer mailbox content from OLM files to IMAP mailbox folder.
  • Now move IMAP mailbox folder data to Windows Outlook.
Refer to this article for complete information - Convert OLM to PST Manually – An Easy Step-by-Step Guide
Thanks.
selvi
Hi
If you are looking to Export Mac mail files to Outlook then you should try out the Best OLM to PST Converter Tool. The one which I am suggesting here is one of the brilliant tool, which is designed and developed with the outstanding technology by which multiple OLM files can be converted in PST file format.
Thanks
Puran
If you are looking to move from Mac Outlook to Outlook 2016 on Windows Platform. Then try this manual solution to precisely export Mac Outlook OLM File to Outlook PST. https://technodiary365.wordpress.com/2018/02/22/how-to-import-mac-outlook-olm-to-outlook-2016-pst-windows/
Apart from Manual Solution, You can also Try SysTools Outlook Mac Exporter Software to effectively and easily import Mac Outlook data to Outlook PST without losing any data. For more information: https://www.systoolsgroup.com/olm-to-pst.html
If you are having OLM files and want all of it in Windows Outlook PST format, try OLM Converter. A strong and effective utility that allows to batch convert OLM files to PST with attachments without Outlook installation. The software is easy to access and does not require Mac OS X for conversion. Make use of OLM to PST converter for Mac software edition and analyses the entire software processing before the final purchase of license key.
