EDB to PST Converter Best Technology
SysOZ EDB to PST Converter is made up by using the advanced combination of the rich algorithm and the best technology. Using it you will easily export email, draft, task, attachment (.TXT, .PDF, .DOX, .XLS, .XLSX, .DOCX, .PPT, IMAGE, ARCHIVE FILE etc.), notes, contact, sent item, delete item, and journals etc. It is a very useful solution for the conversion task. It is very famous for its great work in the data conversion field. You are free to convert your data into various formats like PST, vCard, EML, MSG and HTML.
There are some basic features of SysOZ EDB to PST Converter
• Supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016.
• This utility transfers your all EDB files in PST file without any size limitation.
• Also capable to export OST database directly into Exchange server and Office 365
• You can convert your data into various formats like PST, EML, MSG, PST, HTML etc.
• Support all MS Outlook versions and easily work with all Windows OS 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1.
• Migrate password protected and encrypted data file.
• This tool provides a free trial version to convert 30 emails in many formats.
• Give 30 days’ money-back guarantee if you are not satisfied with this tool.
Read more: SysOZ EDB to PST Converter
alex786
Shoviv is providing a professional EDB to PST Converter tool for those users who are looking for the best way to convert EDB to PST format. This tool works smoothly with the accessible and inaccessible Exchange database and allows them to import into Office 365, Live Exchange server, PST, EML, and MSG. It also lets the user save EDB to HTML, RTF, Cal, vCal, and vCard format. This tool has a free trial version as well.
Know More Info: www.bitdataconversion.com/edb-to-pst-converter.html
EDB to PST Converter application is one of the best conversion tool that make the conversion process smooth and reliable. Before finishing the conversion it shows the preview of recovered mailbox along with emails, sent-items, deleted-items, drafts, outbox contacts, inbox, calendars, notes (To, Bcc, Cc, Subject, From, Object, Date and Time). Apart from PST, it supports cloud-based application Office365 & Live Exchange Server which is a surplus feature of its.
Read more: InQuit EDB to PST Converter
piteralexie
Lots of tools available in the online market to convert the EDB file to PST and but they did not give satisfies result. Therefore here I suggesting to all users to try this eSoftTools EDB to PST Converter Software that is a great solution to convert the unlimited size of EDB file into PST. You can make the conversion of EDB file with all its inner databases such as- emails, contacts, calendars, inbox folders, sent items, drafts, deleted folder items, journals, appointments, etc into PST, EML, EMLX, MSG, and HTML, file formats.
Some unique features of this Free EDB to PST Converter Software:-
  • Automatically finds the location of the EDB file.
  • Able to Recover lost database from the corrupted EDB file.
  • Generate a live preview of all EDB file mailbox items.
  • Supported with all MS Exchange and Outlook versions (up to 2016).
  • Offers a free demo version facility to convert EDB file with 25 email items from each mailbox at free of cost.
Get more info- https://www.esofttools.com/exchange-edb-to-pst-converter.html
