EDB to PST Converter free offline conversion tool
Make the conversion task easy and smooth through the help of InQuit EDB to PST Converter application that is known for its good work. It is compatible with all the version of MS Outlook 97, 98, 2000, 2002, 2003, 2007, 2010, 2013 2016 and 2019 also included. You can select those file which you want to convert from EDB to PST file. The user can see the preview of recovered mailbox along with emails, draft, task, deleted item, sent item, contact, calendar, notes, inbox, journals and attachment (To, Cc, From, Date, Time, Subject, Bcc, and Object). In the free demo version of this tool you can convert 30 emails into PST, EML, HTML, MSG, EMLX, vCal, MBOX, vCard, Office365 & Live Exchange Server file format.
Read more: InQuit Exchange Recovery Software
Enstella EDB to PST Converter is best Tool to convert the .edb files to PST formats very effectively. It also converts the heterogeneous data and given option to save the data into multiple formats like (PST, EML, MSG and HTML). With help this Tool users re access EDB data with Email properties (to cc, bcc, date and subject) without creating any problems. It is embedded with all salient features like –
  1. Convert private and public EDB files
  2. Repairs large EDB files without any data loss
  3. Easily split large PST files
  4. This Tool supports multiple windows versions and MS Exchange server versions (5.0, 2000, 2003, 2007, 2010, 2013 and2016).
Note- Get benefits of this EDB to PST Converter Tool in lowest price at $99.
If your Exchange EDB file gets spoiled due to some reasons so doesn’t go for any other software just I suggest you eSoftTools EDB to PST Converter program which can successfully convert edb file to pst. With the help of this Exchange EDB to PST converter utility, you can access corrupted and permanently deleted edb email data without any difficulty. Conversion is now hassle-free with some steps and after the conversion process, you can convert complete pub1.EDB and Priv1.EDB file to PST and other file options as EML, MSG, EMLX, vCal, MBOX, and vCard.
Know More about the software - https://www.softwaresuggest.com/esofttools-edb-pst
