EDB to PST Converter to Exchange Recovery
SysOZ EDB to PST Converter is one of the best Exchange Server Recovery software which is use to convert the EDB data into PST, you can also convert the data into various other formats like Outlook PST, EML, MSG and HTML. This Exchange EDB Converter software can help you to directly export the data to Office 365 and Live Exchange Server as it can also support the cloud based application. It is possible to see the preview of the conversion with the help of this tool, to check how the final result will look. With the help of this Exchange EDB to PST tool you can do the selective conversion as per your need. This tool is one of the most trusted tool in the market most of the IT Person and big business houses use this tool. With the help of this tool you also split the PST files into smaller bits from 1 GB to 5GB. There is no size limitation you can convert the files of any size there will be no issues. This tool is compatible with all the latest version of MS Window and MS Outlook. This tool will safely recover the inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time) and there will be also no data loss. You are free to try the free demo version of this tool with the demo version you can convert the 30 emails of each folders.
Read more: EDB to PST Converter
For converting your EDB files to PST and recovering the corrupt EDB database, you can use this free EDB Recovery Tool which is introduced by the eSoftTools. This EDB to PST software is a professional tool which helps in repairing any corrupt EDB file. This tool has also a feature to convert the Exchange EDB file into various readable file-formats including PST, EML, EMLX, MSG, and HTML. The EDB Recovery Software has the ability to Export the EDB database like emails, contacts, chats, tasks, notes, journals, and appointments to PST with maintaining all email properties (like- from, to, bcc, cc, size, and subject).
Get More Info:- Exchange Server Database Recovery
alex786
Now one can download a free trial version of Shoviv EDB to PST Converter tool to know how to convert EDB to PST in a hassle-free manner. With the help of this tool, Exchange users can repair corrupted/damaged EDB files, restore deleted items, and export EDB to PST, EML, Office 365, and Live Exchange server. It also lets users save EDB files into MSG, HTML, RTF, Cal, vCal, and vCard format.
Read in detail: www.shoviv.com/convert-edb-to-pst.html
InQuit EDB to PST Converter is a software which help you in conversion and can also help you to save your money and also provide the best results without any data loss. This is available on affordable price with expensive features. It has lots of admirable which makes your conversion process smooth and reliable. In the conversion process, it does not create any difficulty. This tool preserves your data for future use easily and safely. You can try the free demo version of this tool and can convert 30 emails from each folders.
To know more visit: EDB to PST Converter- Repair & Convert Free Exchange EDB file to PST
EDB to PST converter is another effective solution to convert or recover all Exchange EDB file database like emails, contacts, chats, tasks, notes, journals appointments to Outlook PST. The tool is able to export selective single or multiple EDB mailboxes to PST Outlook with a single click. This EDB to PST Tool also provides the other features to export EDB database to several other file formats- like EML, MSG, EMLX, and HTML formats. You can also Download its trial version that converts the first 25 items from per folder of EDB file to PST.
Get More Info:- https://www.esofttools.com/exchange-server-database-recovery.html
