EDB to PST Converter
Wonderfully free download best third-party software for SysOZ EDB to PST Converter Software that can simply extract the damage Exchange EDB file data and provide quick way to convert Exchange multiple mailbox data into PST, EML, MSG and HTML file format with all items deleted items, journals, notes, draft, contacts, calendar, and other many items and Meta properties etc.
Read more: EDB to PST Converter
If you are searching for a perfect and reliable solution to recover or convert Exchange EDB file then choose Shoviv EDB to PST converter Software. This software is considered as the best software for EDB recovery as it has multiple options available for Exchange recovery like it convert or recover EDB data to PST Outlook, Office 365, and Live Exchange Server, EML, MSG, HTML, etc. It has the efficiency to restore data from any damaged condition of the Exchange server and maintain complete data integrity at each process of recovery. Selective recovery is available with an advance option to split PST files into many. But as it is always advisable to try the demo first so a trial version is available on their website for free and it helps to convert or recover the first 25 items per folder.
More details, visit:-
Convert EDB to PST
Exchange EDB to PST Converter Software of eSoftTools provides you the power to Extract the EDB mailbox items to Multiple outlook file formats such as Outlook PST, EML, EMLX, MSG, and HTML. It made to help the user to Recover the Exchange database like emails, contacts, chats, tasks, notes, journals, and appointments from any corrupted EDB file makes it again useable without any MS Exchange server installation. Try a free Demo Version of this software to recover the 30 items from each folder of EDB file.
Get More Info: https://www.esofttools.com/exchange-edb-to-pst-recovery.html
The user can save the entire database into PST, EML, EMLX, vCard, vCal, MSG, and MBOX by using EDB to PST Converter application. Office 365 & Live Exchange Server is the additional features of this tool that store PST file for future use. Before the actual conversion work users can see recovered mailbox then save the resultant file into PST, EML, EMLX, MBOX, vCal, vCard, and MSG. It gives 24x7 technical support.
Read more: https://download.cnet.com/InQuit-Exchange-Recovery-Software/3000-2369_4-77741909.html
EDB to PST Converter Software which perfectly removes all corruption issues from Exchange EDB File and it provides the facility to make the conversion of EDB file to PST with applying some simple conversion steps. This EDB to PST Converter is able to search EDB file location which you want to repair or recover and save entire items of EDB file into PST, EML, MSG, and HTML by date filtering “from date” to “date”. This EDB to PST Converter software recovers the EDB Mailbox items like emails, contacts, chats, tasks, notes, journal, and appointments with maintaining all email properties like as:- to, bcc, cc, time, subject, from, etc. This EDB conversion software compatible with all window versions including- win 7, win 8, win 8.1, win 10, win vista and win XP, etc.
Get More Info: Exchange EDB to PST Converter
Don't go any where else just use the InQuit EDB to PST converter because this tool can do the recover of the deleted data very fast as compare to the other EDB converter, this tool can support various formats like MSG,EML and HTML also. This tool can also do the selective conversion of the files.You recover the Emails, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time). Give a try to this tool and can see by yourself how this tool work, you can go for free demo version of this tool.
Read more: https://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
