Erase Android data Permanently
Alenliu
When we want to change a new mobile phone, how can we deal with the old android phone? According to the survey, most users choose to sell it or give it to friends/relatives. While, if you decide to sell or give away your old Android phone, it will be of great importance to erase data from Android mobile phone before that. If you forget to wipe off files from Android device, some personal info on your phone will be leaked out and exploited by others, which may cause big troubles. There are a lot of Android Data Eraser programs online, they can help us easily do that.
Mobbay
Samsung Data Eraser is a reliable application that allows you to wipe your Android phone completely. You can use it to speed up the device and free up more precious space . It can detect all types of data including photos, music, videos, contacts, messages ,files ,apps and more .
Qmoncetery
This a way to delete Android messages without recovery : SETTINGS --> BACKUP AND RESET --> ERASE ALL THE DATA FROM ANDROID PHONE
Android Data Eraser is your ideal choose of wiping data from Android device, such as amsung, HTC, LG, Sony, Motolora, Google, Acer, ZTE, HuaWei and so on. With the help of the Android Data Eraser, you can easily erase existing data or the deleted data from Android with a click, and ensure the erased data 100% can not being recovered.
JakeTse
Manually deleting data on your Android can't erase them permanently and they can be recoverable. But I've seen cases in which someone had made it possible, but with a third-party app, Android data erasing app. Although those apps offer a free trial, they will cost you a small amount if you want to get the full version.
Edom
You can try FoneDog Android Data Eraser. It can help you erase your data permanently and safely
Iamilery
Erase phone data from Android . as i think , it is not easy to accomplish, no matter how do you delete the phone data , the deleted data will be back on phone again with recovery tool ,
Evan_W
Jihosoft Mobile Privacy Eraser offers 3 erasing palns to help you erase existing or deleted data and 5 erasing algorithm to help you decrease the possibility og recovering deleted data.
Meroy Bacon
Performing a factory reset can help delete all data on your device, but actually these data are not wiped completely. Instead, you can recover them easily by many kinds of recovery tool. So now, Android data eraser is what you immediately need. It can completely and permanently delete all your Android files, and it supports nearly all of the Android devices. You can read this tutorial, how to wipe Android phone, to learn the quick way of wiping Android phone. Hope it helps.
