Eraser 586a Released
Status
Not open for further replies.
Rein
Thanks for the new packs, the first one posted in this thread 5.86a still has the problem I had where the extension installed is the x86 version.
The old style msi installer however works flawlessly so thanks a lot for that.
Thats on XP x64 SP2.
hqdub
admin said:
I have re-released the installer with some minor changes- download again.
All good for me now on x64 Vista. Good job guys!
djjaeger
admin said:
Have gone back to the old MSI type install with two seperate installers for 32bit and 64bit.
32Bit: http://www.heidi.ie/download/erasersetup32.exe
64Bit http://www.heidi.ie/download/erasersetup64.exe
Try these and let me know.
Garrett
Hey Guys, I also was having problems with 5.86 in the downloads section working on vista ultimate 64-bit, but I tried the erasersetup64.exe above and it appears to have instaleld fine. =)
Thanks!!
-Dan
Monk
Eraser 5.86a Solution
Problem -- If you got this error:
An installer package for the product Eraser cannot be found. Try the installation again using a valid copy of the installation package ‘EraserSetup32.msi’.
Must of the time, someone tried to delete all files from the Application without using the uninstaller
Solution
1 – These files “Eraser.dll, Erasext.dll and eraserl.exe” have been left behind in: C:\WINDOWS\system32
2 – Just delete them (just get an Unlocker if you can't...)
3 – Get an old version of EraserSetup584x32
Do the process to install it and when asking to fix or uninstall, check uninstall, than Finish
4 – Download the new installer Eraser 5.86a and install it…
This is an excellent application – I recommended to all
Monk
If you want something done, you’ll find a way: if not you’ll find excuses…
Overwriter
Hi Monk, :)
Welcome to the Eraser forums and thank you for your contribution.
lussato
hi! :D
Could anyone confirm last version md5sum (0ae20406b2c03c0886b419f61911a857)? :?:
thank you! :wink:
Overwriter
lussato said:
hi! :D
thank you! :wink:
Eraser 5.86a hash is
MD5 0ae20406b2c03c0886b419f61911a857
SHA1 ad3b8f317bdeb0a2b4436dd991e246d8ed3468a4
Status
