eSoftTools NSF to PST Converter Software
The software which can help in the situation of Lotus Notes corruption is eSoftTools NSF to PST converter software. It is free from any spyware or malware and allows the user to recover data. This software provides the facility to convert NSF files into numerous file formats such as PST, EML, EMLX, HTML, MSG and many more. It allows the user to split PST file into smaller PST files. It can work well with any version of the Lotus Notes and Outlook. It can be tried for free as there is a free demo present on the official website.
Explore more here: Convert NSF to PST
With the aid of NSF to PST Converter application, the user can convert their data from Lotus Notes to Outlook PST file format without any hassle. You can directly export your data into cloud-based application Office365 & Live Exchange Server for future use. It support PST, EML, EMLX, MSG, vCal, vCard, MBOX and CSV file formats. If you want to break the large file into several small files as per your requirement so you can do this with the aid of this application that is known for its good performance. Before the actual conversion, it can display the preview of the recovered mailbox with all the data of NSF file like email, draft, task, attachment, notes, contact, sent item, delete item etc.
1136
Read more: InQuit NSF to PST Converter
The most preferred NSF to PST Converter Software. It lets the user to Convert data in PST file format. The tool is freely available on the website for trial. The tree structure remains consistent throughout the procedure. This tool works fantastic with all versions of Lotus Notes and Outlook.
Shoviv Lotus Notes to Outlook converter is another effective solution which helps to convert NSF to PST without losing or tampering any content. It converts multiple NSF files to multiple formats, such as EML, MSG, and Html. The tool is compatible with all versions of Lotus Notes, Outlook, and Windows Operating Systems. Download its free trial version and migrate the first 25 items per folder.
More details, visit:- Lotus Notes to Outlook
1162
Using the help of NSF to PST Converter application users can easily export email, notes, contact, sent item, delete item, attachment, sent item, delete item, draft, contact and many more etc. The users save their data into multiple amazing file formats like without any difficulty. Before the actual conversion, it displays the preview of recovered mailbox then store the data into PST. Apart from its support cloud-based application Office365 & live Exchange Server that is the best facility of this program. You can also take its free demo version to convert 30 emails per folder free of cost. It gives 24x7 technical support.
devin
To use this NSF to PST File Converter Online Tool to Migrate Lotus Notes NSF to Outlook PST format. Install and convert the complete database with simple and easy convenience. Free NSF to PST App provides in numerous manners just install check.
More Info :- NSF to PST File Converter
The most renowned and appreciated tool for Lotus Notes migration is eSoftTools NSF to PST Converter Software. It can export NSF file into many file formats such as EML, EMLX, HTML, MSG, PST, and others. A preview of the emails is displayed to the user before conversion. Emails which are inaccessible can be restored with all properties encapsulated in it which comprises of bcc, cc, date, subject, contacts, etc. A free demo is also provided to all users with support to all versions of Lotus Notes and Outlook.
Know more about Free NSF to PST Converter Software here.
