eSoftTools NSF to PST Converter Software
eSoftTools NSF to PST converter can be a nice choice to convert Lotus Notes to MS Outlook. This tool has the ability to recover data in different file formats like PST, EML, EMLX, MSG, HTML etc. It also acts like NSF file viewer software which can view the entire NSF files easily even if they are damaged. All the Meta properties of the email can be restored easily with this software which consists of bcc, cc, date, subject, format, and others. It supports all editions of Lotus Notes and Outlook.
1048
Know more here:
margkerberg
A non -technical user can easily operate ATS NSF to PST Converter application to export Lotus Notes data into Outlook PST file format without creating any difficulty. Using it the users directly migrate their data into cloud-based application Office365 & Live Exchange Server. Before finishing conversion you can see the preview of recovered mailbox along with all the data then convert into PST, EMLX, MSG, CSV, MBOX, vCal, vCard, EML and HTML file format without losing any data. It support Lotus Notes version 9.0, 8.5, 8.0.2, 7.0, 6.5, 6.0 and, 5.0. If you are not happy with its work so you can return it under 30 days.
Read More info: Notes Converter | Export Notes | NSF to PST | NSF to Outlook
The most admired brand in NSF file recovery is eSoftTools. It can restore each and every element of the mailbox including messages, contacts, notes, tasks etc. eSoftTools NSF to PST Converter provides various options for conversion like PST, EML, EMLX, HTML, MSG and many more. The tree structure of the entire database remains as the original one. It has the ability to recover data without any modification in data along with all the properties of each element. All versions of Lotus Notes are compatible with this software.
1061
Explore more here:
http://www.nsf-to-pst.com/
jamesband
Get the more information about how to convert Lotus Notes mailbox to Outlook email application including contacts, calendars, emails etc. using Lotus Notes to PST software. All Windows versions are well-supportable such as 7, 10 etc. It facilitates with so many functionalities for users like- batch option, a preview option, and many others. Opt its free trial version before to purchase the software.
More Info :- osttopstapp.com/nsf-to-pst.html
By taking the help of NSF to PST Converter application you can convert single as well as multiple NSF file into PST and other file formats such as EML, EMLX, vCal, vCard, MBOX, CSV and MSG file format for the future. It supports cloud-based application Office365 & Live Exchange Server. Before finishing conversion it displays the preview of the recovered mailbox in a safe manner along with email, draft, task, attachment, and inbox etc. without any difficulty. This tool always ready to export password protected and encrypted data in a safe manner without any hassle. It is 100% safe and secure for the conversion task.
Read more: InQuit NSF to PST Converter
NSF to PST Converter tool can convert NSF file into Outlook very fast and instantly and this tool give you an Option On To-do list items, NSF to PST Converter can smoothly convert the whole NSF files into PST file with no manual workload. This Software has Option to Save NSF file to PST file format. This Software Migrate Lotus Notes Mailbox to Office 365 or Live Exchange Server.
Bitdataconversion NSF to PST converter another effective solution which helps to convert NSF mailboxes to PST without losing or tampering any content. It helps users to convert NSF to PST, EML, and MSG format. Try its free trial version and migrate the first 25 items per folder.
More details, visit:- NSF to PST converter
Definitely, eSoftTools NSF to PST converter software is the most affordable software with reliable performance. No extra application like Outlook is needed for conversion of NSF file. User has the option to select any number of desired items of the mailbox to exportation in one shot. Even user can migrate Lotus Notes data into various file formats apart from Outlook. A free trial is also provided to check the efficiency of the software. Even a lot of awards are won by this tool from reputed organizations.
Know more about NSF converter freeware here.
