Excel to vCARD Converter
hopemarha
Excel to vCARD Converter can migrate your entire data very safely and fast. The converter tool can easily migrate your Address Book, Tasks, Notes and other things, without any data loss and error. Excel to vCARD migrator is a safe and error-free application with simple steps. Try the DEMO version. If you have any queries for the same then you can simply contact our expert support team for solving the issue 24*7.
By using the Excel to vCARD Conversion solution, the user finds many features to access the converter as it helps to provide 100% result. It saves time and is not much costly. The main feature is it import all Excel address book to VCF quickly.
Visit here:- Excel to VCARD Converter is Fully Functional Tool to Convert Excel XLSX/XLS to VCF
To migrate information from CSV to VCF one can try eSoftTools Excel to vCard Converter Software. Here the user can get Excel contacts in single vCard file or in multiple vCard files with single contact. Also the software has the ability to show the preview before conversion. The user can even modify the contact fields with mapping feature. A free demo version is also offered to each users with support to all versions of Excel and VCF files.
Explore more about CSV to VCF conversion here.
Hi.
Use Excel to vCard converter designed by Sysinfotools. The tool is comprehensive, the full-featured solution to convert XLS/XLSX to vCard format. It is a solid conversion performer to export Excel contacts to VCF format with lots of useful features like Column Mapping, Scanning, Preview, Multiple saving options, and supports all Android and Windows devices. This XLS to VCF converter is a highly demanded tool as VCF file format is widely acceptable by every program, device, and Operating System to store the contact information.
  • Complete safe action by scanning the selected Excel file (XLS or XLSX) for conversion.
  • Map the columns from Excel to vCard fields for conversion.
  • Integrated with the 2 options for exporting the output file: Save Blank Contacts and Create Single File for all Contacts which users can then select either any of them.
  • Users may select the vCard version in which they want to export the Excel contacts to a VCF file
  • Smartly designed for both technical and non-technical users easy for novice computer users.
Go through the video provided below:
Some application is available in the market, you can search through Google, or I will recommend the GainTools Address Book Manager tool, this software will help you to convert emails from Excel to vCard file format. This software supports all Windows OS versions. You can download the free demo version for the application.
Visit here:- https://www.gaintools.com/address-book-manager/
Choosing DRS Excel to vCard Converter to convert all contacts from Excel or XLSX to VCF file would be a wise choice. The software supports conversion of all the Excel file formats such as XLS, XLSX, XLTX, XLSM, XLT, .XLA, XLTM, etc. The software has a very wide compatibility with all the MS Windows versions. The software converts Excel File to vCard or VCF file format with all the information like name, phone number, email, photo, urls, etc. with ease.
Excel to vCard Conversion is a developed software to import XLSX contacts to VCF format. The utility is designed with a graphical interface that makes it easy for all types of users to manage to work on this program. The tool simply deals with any size Excel file plus it does not affect the Migration process due to the number of contacts.
If anyone requires to know how to export multiple Excel files to a VCF file, then don't need to be upset about it, because I have an awesome application that exports your single or bulk Excel file to a VCF file instantly. The solution is SYSessential Excel to VCF Converter software, it has no. of superior features that why it's popular in the online internet market.
Key Features of Excel to VCF Converter
  • The software makes a single vcf file for each Excel file.
  • It can also convert bulk EXCEL contacts files at once.
  • Users can see live previews of all excel files or folders.
  • It operates with all versions of Excel and windows up to 10.
  • For user convenience, it provides free trial editions to convert 10 items free from Excel to Vcf.
If you urgently need to convert XLS contacts to VCF files, try this software system, DataVare XLSX to VCF converter, which was developed for people who wish to transfer their contacts from XLXS to vCard format. As a result, it is a strong software that supports all vCard versions and can convert Excel to numerous files at once. This Excel to VCF Converter program is a special and powerful utility. This software was created by professionals to help users with any issues that may arise while converting Excel to vCard. The Excel to vCard conversion tool allows you to convert XLS/XLSX Excel contact files to VCF files without modifying a single contact field. This software supports all Windows OS versions. You can also download the demo version of this software which converts a few items from each folder.
