InQuit EDB to PST Converter provides you a superlative solution to convert the data from Exchange EDB to Outlook PST file format. At a single time, you can convert single as well as multiple files in just a few simple clicks. It successfully exports emails, draft, task, deleted item, sent item, contact, calendar, notes, inbox, journals and attachment (To, Cc, From, Date, Time, Subject, Bcc, and Object) from Exchange EDB file to Outlook PST file. There are more advantages of the software are discussed given below:
Multiple saving formats: Using this tool you can store your data into several file formats such as PST, EML, MSG, EMLX, MBOX, vCal, vCard, HTML.
Preview facility: Before the actual conversion you can see the preview of the recovered mailbox with full data of EDB mailbox.
Split a large file into several files: Using it you split large EDB file into several small files according to your need.
Supporting version: it support MS Outlook version like 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019 and support OS windows version like 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit).
Support cloud-based application: This application support the cloud-based application Office365 & Live Exchange Server for containing the data for future use.
User-friendly interface: This application is an easy to use application, there is no require any technical skills to operate this program.
BIGGEST OFFER ON ALL PRODUCTS OF INQUIT SOFTWARE
30% OFF
Instant Discount on every Products - Use Coupon Code: INQUIT30OFFER
Read more: InQuit Software
alex786
Shoviv for Exchange EDB to PST Converter tool is providing a complete solution to recover corrupted EDB file, restore deleted EDB file items and convert EDB to PST, EML, and MSG format. Using this tool, users can also save EDB data into HTML, RTF, Cal, and vCard format as well as it helps to migrate EDB to Office 365 and Live Exchange server.
Read in Detail: http://bitdataconversion.com/edb-to-pst-converter.html
Exchange users tried to convert Exchange EDB data to PST formats but don’t get a perfect solution. So I am decided to share a superb solution for you and the name is “Enstella Exchange EDB to PST Converter” which is fully capable to transmit the complete EDB data to PST and other formats “EML, MSG and HTML”. With this Exchange EDB to PST software users never face any type of problems while performing conversions process. And it’s store the Exchange data in desired location without any conditions. It smoothly works with all MS Exchange server versions and windows versions.
Note: Great opportunity for Exchange users to use marvelous EDB to PST Software at lowest price $99.
atssoftware
Most Recommend for Every Exchange Server users, if you are not access Exchange Server EDB file then you Download ATS EDB Recovery Software to 100% Safely & Complete recover Exchange Server Mailboxes data to convert Outlook PST file, MSG, EML, EMLX, MBOX, HTML, and office 365 with Restore existing live Exchange Server version 2007, 2010,2013, and 2016 version.
More Information Software Search In google: ATS EDB to PST Converter
jhonmerijhon
By taking the help of Sys Mail Pro OST to PST Converter application you can easily convert your data from offline OST file to PST file. Its features are great for the recovery of OST data. It supportable to export OST data into PST, EMLX, MSG, HTML, vCal, vCard, EML, MSG. It also supports the Office365 & Live Exchange Server. This tool converts data of OST into PST with full preview before conversion.
Read More Info: Sys Mail Pro
In online market the demand of Enstella EDB to PST Converter Tool is very high because it is superlative tool to convert Exchange EDB files to PST files with all internal elements. Exchange users never face any problems to save the converted data over location machine. Exchange EDB to PST Converter Tool works perfectly in the absence of MS Outlook version in client machine. It supports all windows and MS Exchange server versions.
Note- Get benefits of this EDB to PST Converter Tool in lowest price at $99.
This Software can convert EDB file to pst With the help of this Exchange EDB to PST converter utility, you can access corrupted and permanently deleted Exchange EDB email data without any difficulty. Just some steps and after the conversion process, you can convert complete pub1.EDB and Priv1.EDB to PST and other file options as EML, MSG, EMLX, vCal, MBOX, and vCard. It supports all OS of Windows 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). You can download this software as a free demo version that allows you to convert 25 emails from each and every folder free of cost.
Try free download EDB to PST Converter Software
Easily repair the high-risk corrupt Exchange EDB file data and wonderfully allows you to convert Exchange EDB file data into Outlook PST file format through using SysOZ EDB to PST Converter software. It is safely export the all mailbox items, calendar, draft, journals, notes, contacts, images, attachment, task, junk mail, deleted items and other many items into PST, EML, MSG and HTML file formats within few minutes.
Read more: Download EDB to PST Converter
The Fastest way to convert EDB to PST name as eSoftTools EDB to PST converter software. By this EDB to PST conversion software, user can perfectly Recover and convert the Exchange EDB mailbox database (like emails, chats, contacts, calendars, and appointments) in just a few clicks. It is also able to recover deleted EDB file data with all email properties and attachments. It supports all MS Outlook version includes 2019, 2016, 2013, 2010, 2007, 2003, and below version. Get a free trial version of this software and freely converts 30 items from EDB file.
Know More: https://www.esofttools.com/exchange-edb-to-pst-converter.html
piteralexie
Try the new Shine EDB to PST Converter software that will rapidly convert your Exchange EDB to PST file format within a few minutes. This tool supports all version of Exchange Server including:- 2016, 2013, 2010, 2007, 2003, 2000, and below version to perform the conversion task of EDB file to multiple other file formats. It permits the user to convert the EDB file to Outlook PST, EML, EMLX, MSG, and HTML.
Get More Info:- convert edb to pst
According to my experience, SysInspire EDB to PST converter tool is the best EDB to PST converter tool. It is easy to use and previews the status of EDB file conversion on the screen. Also, it can convert EDB file into various file formats such as PST, HTML, MSG, EML, EMLX, and others. The information is not changed after conversion in any case. A free version is given to all users for trial purpose.
Explore more about free Exchange recovery software here.
