Daisy514
When you forget your iPhone iPad passcode, you can unlock it with the fingerprint you set.
if not, you can still factory reset your iPhone with iTunes, or you can factory reset your iPhone with home button and power button.
for detailed steps about how to factory reset your iPhone without passcode, you can refer to below article:
Factory Reset iPhone without Passcode
Tips: please note when we do factory reset, we'll lose our iPhone iPad data, so we'd better do some backup before doing factory reset.
alanmore
If you forget the posscode of your iPhone/iPad, you need to restore your iPhone with iTunes to wipe all the data on it and then get a brand new iPhone with nothing in it. But don't worry, you can use iPhone Data Recovery to scan your iPhone and then extract all the data you need for you.
Aniketa3
Glad to know about this unlocking software. Thanks a lot!
Alisawangly
In the case that you forgot the password of your idevice, you can use Siri to unlock iPhone passcode for free, but this method is suitable for only a few iPhone, if you have iCloud or iTunes, you should know how to unlock iPhone passcode from iTunes and iCloud for free.
Davaincoal
If we locked iPad, but no have password, how to unlock iPad passcode without restore? We have several methods to unlock iPad password, we can
unlock iPad without a computer, and we can also unlock a locked iPad via iTunes or iCloud, suitable for iPad 1/2/3/4, iPad Mini, iPad Pro, iPad Air, in several clicks.
anthony34
apple products are associated with icloud account, if you mistakenly forgot your iphone/ipad password you could recover it from your icloud account, don't rely on softwares.
JeaninePirro
You can remove the passcode by restoring your device from iTunes or Find My iPhone if you've turned it on before. The catch here is that you will lose your data by following the above method, so you should be aware of that.
If you don't want any data loss, then you should first enter into DFU mode and use apps to get the passcode and paste the code somewhere, then exit DFU mode and input the passcode you just received. This method was recommended by a friend of a local workshop. More details can be found RecoveryTool, and you can leave comments for further requests.
How to get into a locked iPhone
onyiersan
Your iPhone becomes disabled if you have typed in the wrong passcode too many times, it means your iPhone is locked. When you forget the passcode on iPhone, how to remove passcode from iPhone? How to unlock iPhone without passcode? Don’t worry, in this video tutorial you will learn how to unlock iPhone without passcode:
3 ways to reset locked iPhone without passcode - iTunes, iCloud, UkeySoft Unlocker
