Free OST to PST Converter
For converting OST files into different- different formats (PST, MSG, EML, HTML, PDF and MBOX) you should download OST Converter Software from given link. In addition, there is no file size limitations and provides multiple features like Naming convention option to save data according to “from, date+ subject+ from, from+ date, subject” and split option to break oversize PST file upto 5GB. This tool supports all windows version up to 10 and MS Outlook versions up to 2016 (32 and 64 Bit). https://www.softknoll.com/ost-to-pst-converter/
dazzyarral
As per user’s satisfaction, I recommend you to download PDS OST to PST Converter that easily convert .ost files into PST, EML, MSG, HTML, PDF and MBOX formats. The free version of this software restores 20 emails per folder into all supported formats.
ralphmiller
Download free demo version of vMail OST to PST Converter to convert Outlook OST file to PST, MSG, EML, EMLX, MBOX, vCard formats. In the demo version, you can convert 30 emails per folder for free.
OST to PST converter tool recovers corrupted or damaged Exchange mailbox from the corrupt OST file and saves recovered mailbox in Outlook PST file. Outlook OST to PST Converter tool can also recover emails, contacts and other Exchange mailbox items from the password-protected OST files.
InQuit OST to PST Converter application swiftly repairs the damaged offline OST file within a few seconds. This software has a GUI which will display the Emails, messages, calendar, draft. Send items, inbox items, notes, attachments in the preview before saving them into new Outlook PST. It easily breaks your large OST file into multiple small PST file without changes in original data. This tool supports MS Exchange server version 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016.
Read More: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com/
OST to PST Recovery Yet more often than not, it ends up vital to work the letter drop information things. All the letter boxes of client that incorporates variation mail things are spared in OST document. It works with the synchronization with MS Exchange Server. To use mail things, on need to perform OST to PST movement.
Read more:-
http://ostrecoverysoftware.over-blog.com/2018/10/ost-to-pst-converter-software.html
ATS OST to PST Converter tool freely converts the whole data of OST file into PST file format without changing the integrity of OST file. This application support MS Outlook version up to 2019. To see the performance of this tool take free demo version which allows you to convert 30 emails in each and every folder free of cost.
Read More: http://www.blog.bulkecommerce.com/blog/import-ost-2-office365/
Free download one of the best software for SysOZ OST to PST Converter tool to repair and recover the damaged Outlook OST file data and also capable to convert the all mailbox folders like as emails, attachment, images, inbox, contacts, calendar, notes, junk mail, draft into new working Outlook PST file format within few minutes.
Free Download Click here: OST to PST Converter
Also try Vartika Free OST to PST Converter that gives you various choices of formats (PST, EML, MSG, MBOX, HTML, EMLX, vCal, vCard and PDF) to convert OST file. It gives you various advance features and secure conversion process.
Read more- Vartika OST to PST Converter Software
Also use most recommended InQuit for Free OST to PST Converter which is trustworthy solution to fix corrupted OST file issues and then convert OST file to PST, MSG, EML, EMLX, MBOX, vCal, vCard, HTML and Cloud base office365 & Live Exchange Server. It gives you facility to convert selected emails by defining two dates as well as split oversize PST file into smaller parts user define size . It supports MS Outlook: 97 to 2019 (32 and 64 Bit).
Read more : InQuit OST to PST Converter
jamesband
If you want to change a computer and still wants to use your exchange mailbox without exchange connection, you need to export mailbox to PST format and you can then open PST files on your new computer for mailbox view. For export, you may use OST file exporter which safely export all OST files to PST without changing their structure and any loss.
Visit here more info: Soktaken OST to PST Converter tool
Under Free OST to PST Converter from Perfect Data Solutions you can restore 20 emails from every folder. With the free demo version you can understand the functionality and features of software. Free OST to PST Converter supports multiple list of format- PST, Office 365, EML, MSG, HTML, PDF and MBOX.
To convert OST to PST download eSoftTools OST to PST converter tool, this tool securely converts the OST file into more than 6+ formats like HTML, PST Outlook, CSV, EML, MSG, Office 365, MBOX and vCard. Before converting the OST file, this tool shows the smart preview to the user. It recovers the all damaged OST file and folders including E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent items, Calendar, Tasks, Notes, Journal folders. This program supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019.
