My pc has two hard drives.
I did actually use dban to wipe my second drive and was able to reinstall windows 2000 agian..yep,,there was no problem.
By the way, Windows 2000 set up stated there was I/O error or can not detect Arcread boot setor. Anti-virus protection disable on the motherboard too.
My motherboard bios can detect my main one and I did some research it over the internet to solve that issue and it suggested to check for the hard drvie cable and there was no problem.
How do I reconfingure the setting of master and slave hard drive setting on the motherboard?
My pc use dual mode cable which splits master and slave hard drive stuff
Will the problem be fixed if I buy or get a single hard drive cable?
