How do I split Lotus Notes archive file?
Marky
Quickly get NSF Split Tool, if you are looking for a reliable solution to split NSF file or archive file. It is an application which will give you freedom to divide Lotus Notes database as per size, year, date and folder. No file size limitation exists, you can break unlimited NSF file into multiple parts without a trouble. Download NSF Split Tool on all the versions of Windows OS but also make sure that Lotus Notes is installed on the system.
selvi
To swiftly break your large NSF files into small NSF file without troubling the original data. You can easily split your entire Lotus Notes database according to size, date and senders email ID. You can download the free Online NSF Split and try out the features and specifications of the product.
If you have a large NSF database, it may cause serious problems like file management issues. Also, a large NSF file is prone to corruption. In order to avoid file management issues and corruption, you can compact NSF file size. You can do that manually. There's a built-in feature in IBM Lotus Notes which you can use here. Refer to this article for some useful information - Safely Split NSF Database to Manage Lotus Notes Emails
I hope the shared information would be helpful here.
kayra04
Don't think so much to split Lotus Notes NSF files because here NSF Split especially work for splitting NSF database according to size, folder, year, and date with maintaining the originality of content. Free demo facility is available for all users so you can access the NSF Split without any cost. This software is all Windows supportable like- 7, 8, 8.1, 10, XP, Vista, OS and so on.
Best NSF Lotus Notes converter software for complete solution for convert NSF file with all NSF Mailbox items, eSoftTools NSF to PST Converter Software keeps up all mail properties, for example, to, bcc, send and get subjects and so forth. Convert NSF to PST record programming will engage clients to recover NSF email messages, contacts, date-book and all erased organizer things.
See more about hoe to convert NSF to PST easily here .
alex786
Shoviv for NSF Splitter tool provides an easy and safe way to split large size of NSF file into multiple small PST files. You can also try a free trial version of NSF splitter tool.
Read More
