Iris Cheng
Is your Android phone running slow? Are you running out of storage space? Are your apps taking too long to launch?
All you may need to do is to format your Android phone. Without the full storage space on offer, for instance, many of the apps on your phone may not be able to process properly, a reason your phone can launch slow.
Additionally, if the Android phone is low on memory, your phone wouldn’t run fast too. Either way, a clean format can help you get rid of junk files and residual files you do not need, helping your device to get faster.
Source: Three Methods to Fully Format Android Phone Memory and SD Card
