How to Convert iTunes M4P Music to MP3
onyiersan
iTunes music is M4P format,which is protected with DRM.Even though they're digital music, the songs you buy from the iTunes Store aren't MP3s. People often use the term "MP3" as a generic name to refer to all digital music files, but that's not quite right. MP3 actually refers to a very specific type of music file.However,how to convert iTunes music to MP3? how to convert M4P to MP3?
Since music from iTunes comes as AAC, many people believe it is a proprietary Apple format. It's not. AAC is a standard format available to virtually anyone. AAC files work with all Apple products and products from many, many other companies, too. Still, not every MP3 player supports them, so if you want to play AACs on those devices, you need to convert the iTunes songs to the MP3 format.
Apple Music to MP3 Converter also is a top iTunes Music to MP3 Converter works on Windows and Mac platform, which is able to remove DRM from iTunes audio files downloaded from iTunes and convert iTunes Music to MP3,it also convert them to various of common audio formats like AAC, FLAC or WAV format, and etc for playing on MP3 players, iPod, iPhone, Android phones and tablets.
How to Convert iTunes Music to MP3 on Mac
Step 1. Run iTunes Music Converter on Windows or Mac computer
Step 2. Add Music to Apple Music Converter from iTunes Library
Step 3. Set Preferences of iTunes Music Converter
Step 4. Start iTunes Music to MP3 Conversion
When finish customization, click "Convert" button to start convertion. If you don't want to convert a certain music, please click remove button button to remove this music before converting. After conversion, you can click history button to find the converted audio files.
Video Guide:
Read More:
How to Convert Spotify Music to M4A
korence
As I know, if you want to play iTunes music on any non-Apple devices. You need to remove DRM protection at fist. Since all iTunes music, video are encrypted with fairplay DRM protection. The best DRM removal software that I have used to convert iTunes music to common MP3 format is Tuneskit Apple to MP3 Music Converter. It works at 30x faster speed to keep quality losslessly. Hope this point is useful to you. Now you can check more info on This homepage.
Salinamati
We need remove DRM protection of Apple Music at firstly, Apple Music can be only played in Apple device with the protection of DRM. Convert M4p to MP3 with the help of Eelphone Apple Music Converter, you can free enjoy Apple music in other mobile device or players. Select the Apple Music playlist you want convert to MP3 now.
