If you search on Google about the ways to convert NSF to PST then a huge list of results will be found. Simply choose the most suggested method like choosing smart tool such as eSoftTools Lotus Notes to Outlook converter software. It prompts the user to migrate in various file formats which include EML, EMLX, HTML, MSG, vCard, Outlook, etc. Select the Outlook (PST) option and then choose the saving location for the output file and it's done. It is a three-step process in short. Not Outlook installation in advance is needed by this tool to perform its function. The data is re-established as the original database and hence no modification is made. A free demo version is also provided to each user.
Explore more about free NSF to PST converter software here.
