How to Convert OLM to PST for Mac?
Mailvita OLM to PST Converter for Mac software is an email conversion software for Outlook data file. The primary function of this application is to safely convert Mac Outlook data to Outlook PST without losing any data.
Key Features
  • Can Convert OLM file to Outlook PST without losing.
  • Convert every folder of OLM file including Inbox, Outbox, Sent Items, Drafts, Contacts, Calendar, etc. to PST.
  • Maintains email properties to cc, bcc, date-time, subject, and attachments during and after the conversion.
  • No limit of OLM file size with the software.
  • Supports Outlook 2016, 2013, 2010, and more versions of Outlook and Mac OS.
  • View Converted OLM file emails in this same software.
I would like to suggest KDETools OLM to PST Converter to 100% safely converts Mac OLM to PST.
Try this Mac OLM to PST Converter utility which provide 100% fast, safe and secure results. You can easily migrate and convert large Mac OLM files to PST format for MS Outlook 2019, 2016, 2013, 2010, 2007 etc.
See more info: http://www.olm-converter.com
For converting OLM file to PST I get the easy solution for you, you can use ToolsGround OLM to PST Converter Software is the perfect tool to convert multiple OLM files to PST at once. The tool comes up with many features. With this software, users can easily save the converted files to the required location. It provides the complete preview of OLM files before the conversion. The tool supports all the versions of Windows OS & Outlook.
More Info;- https://www.toolsground.com/olm-to-pst-converter/
