How to Convert OST to PST Software
InQuit OST to PST Converter can do the following features:
• You can see the preview of the recovered mailbox before the conversion.
• Size Limitation of OST file doesn’t matter.
• This tool support OS Windows- 95, NT, 98, 2000, ME, XP, Vista, 7, 8, 8.1, 10 (32bit & 64bit).
• It supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016.
• It is capable to export OST database directly into Exchange server and Office 365.
You can convert your data into formats like EML, EMLX, MSG, HTML, vCal, vCard etc.
• It provides a free trial version to convert 30 emails in each folder.
ruchika
Ignissta OST Converter software is best software which helps you to convert large and corrupted OST file to PST file. You can convert single as well as multiple OST file at once.
Important Features about Ignissta OST Converter
  1. No File size limitations, Convert unlimited OST files
  2. Capable to convert multiple file format such as PST, Vcard, EML, MSG, MBOX
  3. Ignissta OST Converter Also Capable to migrate from OST to Office 365
  4. Split option is there to convert large OST file to small size of PST file
  5. Provide 100% safe and secure conversion results with 100% data accuracy
Download OST to PST Converter and Convert OST to PST file https://www.ignissta.com/ost-to-pst-converter/
Simple and Easy way of OST to PST Conversion
Browse and Select OST file --------------> Preview Email Items ---------------------> Export to PST file
alex786
If you need to know the process of OST to PST Conversion, then you can download a free demo version of Shoviv OST to PST Converter tool. It will help you to know how to convert OST to PST in a hassle-free manner. Once you get to satisfy with trial version after that you can go with a full licensee version to import unlimited accessible and inaccessible OST files into PST, Office 365, Live Exchange Server, EML, and MSG.
Get More Info: www.bitdataconversion.com/ost-to-pst-converter.html
The users can export their data into many interesting file formats like PST, EML, EMLX, MSG, vCal, vCard, and MBOX. Apart from its support cloud-based application Office365 & Live Exchange Server. It does not consume more time in the conversion work. For your satisfaction, you can take its free demo version that allows converting first 30 emails from each and every folder that is absolutely free of cost. You can also return it under 30 days if you are not happy with it.
Read more: Free OST to PST Converter Tool
jamesband
Try this best OST to PST Converter to transfer OST emails to your MS Outlook profile. This OST to PST tool is so reliable and accurate that it takes a few moments to move a bunch of OST files to Outlook PST format and maintains the integrity of data. So hurry up and download the trial version of the application that migrate first 10 emails to the Outlook format. Visit:- https://www.softakensoftware.com/ost-to-pst-converter.html
