How to Convert unlimited EDB mailbox into PST file
The IT experts designed a great tool by using the highly advanced algorithm that name is InQuit EDB to PST Converter software. Using this user can extract their data such as email, contact, draft, task, calendar, attachment, and notes into several file formats such as PST, EML, EMLX, vCard, vCal, MSG, and MBOX.
Apart from it support Office365 & Live Exchange Server which is a cloud-based application. This utility does not make any changes while you convert the data from EDB to PST. It has a preview facility which shows the preview of recovered mailbox before the conversion and provides 100% accurate result.
It is compatible to work with all the version of OS Windows up to Window 10. During the conversion process it does not make any changes in the database. The users can also export any sized EDB file into Outlook PST.
The users can also download its free demo version to convert 30 emails from each and every folder free of cost. If you are not happy with its work then you can return it under 30 days.
Read more: Free EDB to PST Converter
You can convert your large EEDB file into PST file without consuming more time with the help of SysOZ EDB to PST Converter application. The size of the EDB file does not matter for the conversion. It has multiple features that help to recover data from EDB and convert them into new Outlook PST. You can convert your data into various different formats such as EML, MSG, HTML and PST.
Read more: Free EDB to PST Converter Download
jackbryan
Whenever facing any EDB file corruption error in your Exchange Server because of virus attack so don’t be irritated because here I recommend you the best solution to fix this problem name as eSoftTools EDB to PST Converter Software.
It will give you some highly advanced features to repair the damage or corrupt EDB file and also allow users to convert them into PST files and other readable file formats like MSG, EML, HTML, and EMLX.
OST to PST Software has no file size limitations and the user can easily convert unlimited EDB files into each format without getting any problem.
This tool works smoothly with all versions of Exchange Server and MS Outlook including- 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, and 2016.
Steps to Export EDB Mailbox into PST file:-
  1. Open the Software.
  2. Select the EDB file.
  3. Load all its inner mailbox items.
  4. Choose file type PST
  5. Start the conversion and export EDB to PST
