How to Fix iPhone That Stuck In Recovery Mode?
ammyour5
Get your iPhone that stucking in recovery mode due to iOS update/downgrade/jailbreak, or because of the unknown reason? To get iPhone out of recovery mode, you can not miss the iOS System Recovery.
iOS System Recovery is the world's 1st data and system recovery program for almost all iOS devices. With its help, you can easily to fix the abnormal iOS return to normal without losing data.
Step 1. Install and run the program, and choose the repair iOS system feature.
Step 2. Download and select firmware for your iPhone.
Step 3. Fix your iOS to return it to normal.
Related: Fix iPhone stuck in apple logo screen
If your iPhone is stuck in recovery mode, you can restore your device to fix this problem. You can refer to this article:
How to Get out of Recovery Mode on iOS 11
Actually, no matter what reason makes your iPhone stuck in recovery mode, you can use the method mentioned in the article to fix it.
Hope it will be helpful for you.
brant
If you suffer from iPhone stuck in recovery mode issue. You can do the following things.
Firstly, you can press and hold the "Home" button and the "Power" button to hard reset your iPhone.
Secondly, if the first solution can't work, you may need to use iTunes to restore your iPhone to normal.
Thirdly, you can try to download an IPSW firmware to fix your iPhone device.
Ellinor William
None of these worked for me. then there was this rather inexpensive and effective software called Stellar Phoenix Data recovery for iPhone that worked for me.
AmandaColey
First is to force restart your iPhone, which is the simplest way to fix it. Just press your home and power button together for about 15 seconds till you see the apple logo. But this method doesn’t work every time.
Another method is to try DFU mode. Just connect your iPhone to iTunes, press home and power button together till the apple logo appears. Then release the power button but continuing to hold the home button and wait for the iTunes to tell you that it’s in the restore mode. In this way, your iPhone will detect to iTunes without activating the boot loader, and then restore successfully.
However, if the above methods are useless for you, try to use iOS System Recovery from FORecovery for help. This program can assist you in solving common bugs and software issues with iOS devices without losing your valuable data.
Detailed introduction of the above three methods can be found here: How to fix an iPhone stuck in recovery mode. Hope this helps.
onyiersan
You iPhone stuck in recovery mode after iOS 11 update or downgrade?You can use iTunes to restore your iPhone and get it out of recovery mode,but this way will cause data loss.
However,I recommend you this iOS System Recovery tool,which can help you fix iPhone stuck in recovery mode without data loss.What's more,it also can help you fix iPhone stuck in apple logo,etc.
Read More: how to get iPhone out of recovery mode
stephanic
Hi,
This is the situation which many iPhone user face. However there are ways by which you can fix iPhone stuck in recovery mode. Go through the below mentioned link and know how to fix iPhone stuck on recovery mode easily.
See more on: Fix iPhone stuck on recovery mode
BellyBlack
iPhone stuck on apple logo?
Step 1) Plug in your iDevice into your computer using the USB cable.
Step 2) Press and hold the sleep/wake button and the home button simultaneously. Continue holding until the screen turns black and keep holding until the Apple logo reappears.
Step 3) If this does not work and the iDevice is still frozen on the Apple boot screen, follow the instructions here.
qoulisse
When iPhone stuck recovery mode, try to force restart iPhone, if force restart iPhone can't fix iPhone, you should turn to the tool to fix iPhone stuck in recovery mode. With the deatiled guide, we can fix the iPhone in clicks.
