How to Fix Outlook PST error “.pst is not a personal folder file”
MicMatz
Outlook Errors - PST Is Not A Personal Folder File. How can i fix Outlook PST error? Give me right solution about it..........
selvi
Hi
PST is a Personal Storage Table which stores Outlook mailbox files in PST file format. These files might get corrupt due to some issues like fluctuating errors, Insufficient memory and all. The best part is that you can easily fetch out your files very easily by using PST Recovery Software which is smartly developed by SysInfo Tools.
Thanks
Marliza
This error ".pst is not a personal folder file" can be recovered by the use of a professional tool. Here it is advised to use SysTools Outlook Recovery Tool. By the use of this utility, the users can repair Outlook PST file without any extra effort.
With a proficient and secure Outlook PST recovery software, you can easily repair corrupt PST file and recover the stored data, including all emails and their attachments. You can also use it to move PST file in EML, RTF, MBOX, IMAP, MHTML, PDF, PST, MSG, TXT, DBX, and HTML formats. To know more about the tool, visit: http://www.pstrecoverytool.org/
alex786
Here I would like to recommend you one more proficient tool named Shoviv Outlook Recovery Software which effectively works to recover damaged Outlook PST file without any data loss. This software also has a feature of exporting recovered PST file to Live Exchange Server. It also has a free trial version and good technical support team.
jamesband
You can fix the Outlook PST file by recovering its data from damaged PST with the help of some third-party tool like Outlook PST Recovery tool. This software will allow you to repair all the damaged data of the PST file and save it into a new file either it PST or other file format like MBOX, EML etc according to user choice. To try this tool you can visit here:- https://www.softakensoftware.com/pst-recovery.html
You can easily resolve this error by using the PST Repair Tool by SysInfoTools.
Goto: SysInfoTools PST Recovery
The utility repairs the PST file that is corrupt due to various reasons and restores the mailbox completely. This is a simple to use utility that has simple to use GUI and can be used even by a non technical person. It supports all the versions of Windows OS.
