How to Rebuild PST File
Rohan Wiese
Do you want to rebuild a pst file when your PST file corrupted due to any reason? Try free simple method to rebuild pst file of any version of MS Outlook after that easily open or access with all versions of MS Outlook.
Make sure Outlook Application is closed.
Click Start, then Control panel.
Click Folder options or File Explorer Options, then switch to the View tab
Under Hidden files and folders, make sure the Show hidden files and folders option is selected, and then click Ok.
hidden files
Browse to the location of your Microsoft Office installation:
If you cannot find the scanpst.exe file using Search, try to locate the file manually. Check the following locations for the file (location depends on which version of Windows you are using):
scanpst
Note: if scanpst.exe file still cannot be located, try to repair Office programs and rebuild pst file.
Click Browse to locate the corrupted .pst file
Click Start. The Inbox Repair Tool scans the file and reports whether it found any errors. Click Repair if any errors were found.
Click OK.
Free Download Full Version Outlook Recovery Tool
I would like to suggest you to use of third party DataVare Outlook PST Repair tool to successfully recover all PST mailbox data like emails, tasks, appointments, journals, decorated text, email properties, zipped attachments, notes, drafts, scheduled tasks, etc. from corrupt PST files. The software Operates in two recovery modes: Standard & Advanced.
