How to Recover data from android phone using Mac?
Cassatty
I strongly recommend you to use the Android Recovery Mac, which can help you recover almost all deleted and lost data including call logs, photos, videos, audios, text messages, contacts, and so on from almost all Android devices and SD cards
AmandaColey
The lost text messages, contacts, photos, you can use recovery method to recover them.
You can try this data recovery program to scan your phone and restore lost data from it - FORecovery Android data recovery for Mac.
Only a few steps you can get back your lost data from your phone:
Step 1: Run the data Recovery tool and connect your phone to Mac
Step 2: Scan your lost data from your phone
Step 3: Preview the found data and start to recover.
Incidiya
Use FoneDog - Android Data Recover. It is suitable for Windows and Mac. You can choose Mac version.
You can try FoneDog - Android Data Recovery. Here are the steps:
Step 1: Download and Install FoneDog Toolkit.Connect Your Phone to Computer.
Step 2: Select The File Types to Scan Your Device for.
Step 3: Scan Your Device to Find The Lost Data.
Step 4: Preview The Scanned the Data and Recover Them.
kaoler1
I know that Android Data Recovery program can help you recover data from android phone. It supports all Android brands, including Samsung, HTC, Motorola, Google, and so forth.
Before starting recovery process, you can preview all the files from your Android phone, including the existing files and deleted files. You can select the data which you want to recover.
how to recover deleted music on android
