How to Recover Data from Broken/Dead iPhone?
#1
Sometimes, fixing a broken/dead iPhone may cause data loss. Therefore, it is a priority to extract important data out of your broken/dead phone before you decide to fix it.
If you want to save/recover your data from broken/dead iPhone, this post is worth watching:
Hope it will be helpful for you!
#2
Well, when you have done some backups on iTunes and iCloud, we can restore our lost iPhone iPad data from iTunes and iCloud backup even it doesn't support us to do it selectively, see below steps:
for iTunes:www.irefone.comwww.irefone.com
Launch iTunes, connect your iPhone with PC. Then go to Files--Summary, then you can see your backup files on the left side bar, choose the backup files you need.
Click "Restore Backup" on the right page, and confirm with "Restore".
for iCloud:
Connect your iPhone with Wifi, log in iCloud with your Apple ID and password.
Now go to Setting--General--Erase All Content and Settings, when all content and settings are erased, go to set up assistant with a hello screen.
Swipe to begin the set up process, choose the backup files you need, tap on "Restore Backup", and confirm with "Restore".
If you have no backups, don't worry, you can come to iRefone for help.
#3
You are right. Actually, if there is a backup of your broken dead iPhone, you can directly recover them from backup files. If you don't want to recover all backup files, you can try iPhone data recovery tool to help you get back data you want.
#4
The iPhone data recovery tool enables you to recover data from dead iPhone , like photos, contacts, text messages, notes, reminders, calendar, Safari bookmarks, app data and so on, no matter you use to old iPhone model or latest version of iPhone X/8, it allow you to preview deleted data to select the ones you need, no matter you make a backup or not.
how to recover data from water damaged iPhone
I know a program can do this. It can scan your dead iPhone deeply to find the data on it. You can preview the data before recovering. It can recover messages, photos, videos, contacts, call history, notes, reminders, calendars, voice memos, voicemail, safari bookmarks, Whatsapp messages and other data from your dead iPhone to computer. Learn how to recover data from dead iPhone.
