How to recover deleted whatsApp Messages on Android?
WianWang
how can I recover my deleted whatsApp messages on Android??
Edom
ou can try FoneDog – Android Data Recovery.
  • Recover photos, videos, contacts, messages, call logs, and more.
  • Recover Data from Android phone, SD Card, Broken Android in Different Situations
  • Compatible with almost all Android devices.
  • The best recovery tool for Android and 100% Safe Guarantee
Here are the steps:
Step 1: Download and Install FoneDog Toolkit.
Step 2: Select File Type
Step 3: Select Mode
Step 4: Select Files to Recover
Finally, you get to recover your WhatsApp Messages! Hooray!
A complete guide: How to Recover Deleted WhatsApp Messages on Android
alanmore
if you want to get back the deleted whatsapp messages from your android phone, you need to use Android Data Recovery program. It can scan your Android phone and SD card deeply to find the deleted Whatsapp messages for you. You can preview them and then recover them for you. Learn how to recover deleted Whatsapp messages on Android phone. Besides Whatsapp messages, you can laso recover deleted text messages, photos, videos, contacts, call logs, Whatsapp images, music, books and other document files from your Android phone.
Cassatty
Android Data Recovery can help you get out of the suffering from losing messages from Android phone,that you lose your data accidentally,enables to backup and recover lost data from android phone.The program help you recover lost data from Android phone and tablets with several steps,including photos,contacts,SMS,call logs,audio,video,documents,etc,
Alenliu
First connect your dead Android phone to computer via usb cable, if it can be detected by computer, just use Android data recovery software to help us recover your deleted whatsApp messages on Android.
Incidiya
Certain times though, the backup you have may not be ideal and you may end up losing data on Samsung device that is not in backup files. In these situations you need a way to recover lost data. Fortunately for you, we have the best solutions to recover deleted or lost data from Samsung Computer or Mobile phone. Use FoneDog – Android Data Recovery.
Features:
Here are the steps:
Step 1. Launch FoneDog Toolkit.
Step 2: Connect Your Phone to Computer.
Step 3: Select The File Types to Scan Your Device for.
Step 4: Scan Your Device to Find The Lost Data.
Emma_0117
hey guy, don't worry.It's very easy for you to recover deleted WhatsApp from Android Phone with the help of FORecovery Android data recovery. This powerful tool could be the best assistant to help you restore lost Samsung, Sony, LG, OnePlus, Huawei, etc. WhatsApp messages. With it, you won't suffer a lot from losing data. However, in order to android restore contacts phone completely, you should stop using your phone do any editing work. As you know, the reason why a recovery program can help you retrieve deleted text messages is that your lost messages data are still stored in somewhere of your phone.
let me tell you the data recovery steps of this toolkit easily.
First step: connect your phone and PC
Second step: select the data types you need to recover
Third step: data scanning
Fourth step: preview your data item and recover them
Read the following article to get more details if you need.
Hoping it will work for you and you would recover deleted WhatsApp messages on Android. Good luck to you.
Cacaterg
To recover deleted messages on your Android phone , you can try the Android Data Rescuer ,
kellyiee233
First, you should stop using your Android phone, because the newer data will overwritten your deleted messages and you might not get a chance to get them back. Second, download a Android Data Recovery software to help. Remember, when you get to the step of selecting categories, you should mark whatsApp and whatsApp Attachments. Then click RECOVER. The deleted messages will be recovered on your computer. Hope this will be helpful for you.
Related Article: How to recover deleted whatsapp messages on android
juniorwu1124
Check this step by step guide:
How to Recover Deleted WhatsApp Messages from Android
You can get back your lost WhatsApp chats by following these steps:
  1. Install and run Yolisoft Android Recovery on your computer
  2. Connect your phone to computer with USB cable
  3. Scan your phone to search for lost WhatsApp data
  4. Preview and recover the items you need
Hope it helps.
kou
Here is something that I know how to recover deleted WhatsApp messages.
Assuming that you just want to restore recently WhatsApp coversations, you can uninstall and reinstall the WhatsApp app in your cell phone and then you will get a message which prompts you to restore WhatsApp messages. Or you can use a safe WhatsApp message recovery program to extract WhatsApp files from your smartphone.
kaoler1
