How to Recover Photos from Water Damaged Samsung A5?
gjkyuiu
There are so many important data and information located in your Samsung Galaxy A5, such as Samsung Galaxy A5, you just dare not to think about losing them because too many inconvenience would be brought to you after the loss of your phone data. Don't panic just yet there is possible to get back files from a water damaged Samsung Galaxy A5.
If your Samsung galaxy A5 unfortunately gets malfunctions caused by water damage, the first thing you should do is to save the data on phone before fixing it. Then how to recover data on water damaged Samsung galaxy a5?
Method to Recover Deleted Photos from water damaged samsung A5:
You can try the Samsung Data Recovery to help you recover contacts, text messages, photos, videos, music, call logs and more other major data directly from water damaged Samsung phone easily and completely. It supports almost all Samsung phone models, such as Samsung Galaxy S8/S7/S6/S5, Note 7/6/5/4, A9/A8/A7, etc.. You can preview the lost data previously so as to perform an time-saving and accurate recovery process.
More info:
Recover Data from Samsung with Broken/Death Screen
alanmore
If your Samsung phone is water damaged, you need to use Samsung Data Recovery to scan it to find the photos on it. You can then preview them and recover them from your Samsung phone to computer. learn how to recover photos from Samsung phone here. You can also recover messages, contacts, call logs, videos, Whatsapp messages, music, books and other document files from Samsung phone.
Alenliu
To Recover Photos from Water Damaged Samsung A5, first make sure your water damaged Samsung A5 can be detected by computer via USB Cable. If yes, you can use Samsung data manager tool to help you get access to all photos and export them to computer for backup.
Edom
Make sure your phone can be detected by computer. If yes, then you can use Fonedog toolkit to scan your data and recover your files.
You can try FoneDog - Android Data Recovery. Here are the steps:
Step 1: Download and Install FoneDog Toolkit.
Step 2: Connect Your Phone to Computer.
Step 3: Select The File Types to Scan Your Device for.
Step 4: Scan Your Device to Find The Lost Data.
Step 5: Preview The Scanned Data and Recover Them.
Cassatty
Thanks to Android Data Recovery,you are able to recover lost photos from android phone directly.Besides,Android Data Recovery empowers to restore various types of Android data,including messages,photo,video,call logs,calendar,note,apps data and so on.
WianWang
Recover Android Data from Damaged Devices:
Step 1. Download and install FoneDog toolkit – Android Data Recovery. Then connect Your Android Device to Your Computer.
Step 2. Choose the data types you would like to recover from the damaged device.
Step 3. Select The Fault Type that Corresponds to Your Android Device.
Step 4. Choose “Device Name” and “Device Model”.
Step 5. Confirm to Continue The Recovery Process.
Step 6. Enter The Download Mode.
Step 7. Select The Files to Recover from Your Device.
Lillllian
Maybe you need a third-party helper if you do not have any backups. Try Yolisoft Android Data Recovery.
onyiersan
When your Samsung phone is broken without backup, and you can't find an effective way to recover data from broken Samsung phone, then you may lose them permanently. A good news that you can use a 3rd-party Android data recovery application to recover deleted photos from Samsung phone easily.
Here, we kindly recommend a reliable yet professional Broken Android Data Recovery software for your reference.
Let's learn the guide about how to recover photos from damaged Samsung phone.
Read More:
Recover data from water damaged Samsung phone
