How to Remove Forgotten Passcode from iPhone X without iTunes ?
BrevinRatliff
When you entered incorrect passcode on your iPhone x too many times, you will be locked out and a message like "iPhone is disable'. Would like to fix the disable iPhone? Luckily this Dr.Fone Unlock can help you remove forgotten passcode from iPhone X without iTunes .
Warning:
First, turn off 'find my iPhone'
Second, all data will be erased from iPhone.
Alisawangly
If you no have iTunes, you can use iCloud to unlock iPhone passcode, but you need know the Apple ID and the Find My iPhone in your device must be on. Then you can unlock iPhone passcode for free. You can also put your device into DFU or Recovery Mode to unlock iPhone passcode for free, it also will erase your data from iPhone. But Eelphone iPhone Unlock can unlock your iPhone passcode in steps.
BrevinRatliff
No matter if you turn off the 'Find my iPhone' this dr.fone - unlock for iPhone can help to unlock your iPhone
