How to Save Hotmail Email Backup to Hard Drive as PST, EML & PDF
Rohan Wiese
Simple Steps to Save Backup Emails from Hotmail to Hrad Drive as PST, EML & PDF
A step by step guides to take email backup from Hotmail or Outlook.com using Hotmail Backup Software.
You can easily take email backup from Hotmail and export them into different email clients as well as save backup emails into a various file format.
Step1. Runs Hotmail Email Backup Tool
Step 2. Once the software is launched Enter the Hotmail User ID & Password and Click on Login
Step 3. As soon as you Select Email Format or Email Clients in which you want to
export or save Hotmail email backup.
Hotmail Email Backup Save as PST to Hard Drive
Choose PST from Select Email Format dropdown list
Click on Browse button to Select Destination Folder, where you want to save Hotmail Backup Email as PST file.
Click on Browse button to Select Temporary Folder for temp file.
Now click on the Next button, after that select Hotmail folder from Select Folder option
Export Hotmail backup email according to date range - Select from Date and
To date and click on Add button
If you want to delete emails from Server after download then Check Out
Deleted After Download then Click on Next button
Now Exporting process is started.
After some time popup windows open - All files save successfully at a selected folder or destination folder then Click on OK button
Read More: Hotmail Email Backup Software to Backup Emails from Hotmail/Outlook.com
jamesband
If you are having trouble in saving your Hotmail emails data into your local hard-drive then you can take help of Softaken Hotmail Backup Tool. This software is one of the most reliable and safest applications available for taking a backup of your emails data from Hotmail Mailbox with full accuracy. This supports all updated versions of Windows OS. To know more kindly visit here:- https://www.softaken.com/hotmail-backup-pro
