How to split large PST files into multiple PST files?
johnlocke
Efficiently splits a large PST file into smaller and manageable PSTs, based on specified PST split criterion, such as Date, Size, Mail Id and Folder.The software maintains data integrity of the original PST file. After splitting a large-sized PST file into smaller pieces, they can be easily accessed with MS Outlook and are completely independent of original PST file. To download visit :- undeletepcfiles.com/ split-pst-file . html
Rohan Wiese
You can try Split PST tool for splitting large pst file, software maintains data integrity of the original PST file. After splitting a large-sized PST file into smaller pieces, they can be easily accessed with MS Outlook and are completely independent of original PST file. http://www.arysontechnologies.com/split-pst-file.html
Already discuss on: https://eraser.heidi.ie/forum/threads/split-pst-file-how-to-split-large-pst-file.11678/
Thanks & Regards
Rohan Wiese
Riya Thomas
Hi,
To split large PST files into multiple PST files, you can use Import and Export feature of Microsoft Outlook. It can do the dividing task in an easy manual way. But if you are searching for any automated technique to make your work perfect, then you can try SysTools Split PST software which can break PST files into smaller parts without any hurdle.
Thanks & Regards
Riya Thomas
Using Outlook PST Split software will be very helpful for users and it will split large Outlook pst file into small one without any issue. It can select large PST file from its location and splits them into multiple small PST files. This feature is useful for PST splitter utility that helps to avoid PST corruption and over-size.
alex786
Try one more fine solution named Shoviv PST Splitter to split oversized PST file into multiple smaller parts. This is a reliable and secure tool which provides an easy solution to split large PST file into multiple small PST files. It has a free trial version and a good technical support team as well.
Source: PST Splitter Tool to Split PST File
Alright, I am here to share an important solution by which you can simply split your large sized Outlook PST files into multiple PST file of small size. Here is the Split PST Tool which is a genuine and remarkable option for those users who are worried about the large size of there PST file. This application can run on all versions of Windows and Outlook. This tool very simple to operate without facing any error.
camilia
Try this excellent Outlook PST Splitter tool that can split large or oversized PST files into small multiple PST files without losing any data. The software offers four ways to divide PST file.
Split PST File by Date
Split PST File by Size
Split PST File by Year
Split PST File by Folder.
The tool helps the users to avoid the risk of corruption of PST files due to the issue of being over-sized. It is well compatible with all the versions of MS Outlook and Windows OS.
Download For Free and Install: Split Oversized PST File into Small PST - PST Splitter1489
ruchika
I would like to suggest Ignissta PST splitter and merger software which helps you to split pst file and provide safe and secure results without any data loss also provide 100% data accuracy. User can split pst file with multiple features like
Split pst file options
# Split PST File According to Various Size (MB or GB)
# Split PST file According to specific Date Wise
# Split PST file with Single Email ID
# Select Mails and Split
This software also capable and allow to merge multiple pst file to single pst file and also remove duplicate emails items while merge pst file
Merge PST File
# Merge Multiple PST file to New PST file
# Merge Multiple PST file with Exisiting PST file
Remove Duplicate Emails
While Merge Multiple PST file you can remove duplicate emails.
Download Trail Version and Split PST File with first 50 Emails items https://www.ignissta.com/pst-splitter-merger/
If you don't want to lose the structure of the original PST file after splitting, then use ToolsGround Split Outlook PST tool is the best choice to fulfill your needs. This software easily split large PST files into multiple smaller parts with all data items like emails, contacts, calendars, etc. It maintains the integrity of data while splitting and provides a 100% accurate result.
More Info:- https://www.toolsground.com/split-outlook-pst/
samuelsarah
The Merge PST file allows you a combine entire data of PST to one file or folder. It also merges the different size of files or unlimited files also. The Merge PST files give you 100% accurate results and never lost your valuable data. It’s suitable for ANSI and UNICODE PST files. The advanced Merge PST Converter works very well with Microsoft Outlook versions.
Visit here:- https://www.mailsclick.com/merge-pst-file/
