How to Transfer Data from iPhone to iPhone XR?
ammyour5
There is news that the foreign media has once again exposed the iPhone XR. The foreign media said that the iPhone XR is a 6.1-inch cheap version of the iPhone X, which has an appearance similar to the iPhone X and will use an LCD screen, in order to reduce costs. At the same time, the iPhone XR will also bring a single camera, and there is no wireless charging, these are considered for the price.
It is worth mentioning that although the iPhone XR has compromised in some places, it will not compromise in terms of performance. It is reported that the iPhone XR will be equipped with the Apple A12 processor, and at the same time with the iOS 12, will bring a more smooth and stable experience.
Are you can not wait to buy a new iPhone XR to replace your old iPhone? If so, you must be looking for a simple way to sync all your personal data including contacts, photos, videos, text messages and more from the old iPhone to iPhone XR, right? Well, take it easy, to transfer data from iPhone to iPhone XR, what you need is just the Phone Transfer.
Phone Transfer is the outstanding data tranfser program which can transfer photos, contacts, music, videos, calendars, call logs, messages, apps and app data for you. It supports iPhone, Android Phone, Blackberry, Nokia, Windows Phone perfectly. With it, you can copy data from one phone to another without any difficulty. Besides, you can backup and restore your iPhone data by using this tool.
Related: Transfer Data from Samsung to iPhone XR
Alenliu
It's ture that you can use iTunes to help you Transfer Data from iPhone to iPhone XR, but it's not easy. You need to recover from iTunes backup and it may happen error. My suggestion is using pro phone transfer tool to help you transfer data between them.
