How to Transfer Data from iPhone to iPhone XS(Max)
ammyour5
iPhone Xs Max will be the largest screen ever iPhone, and it will be equipped with a similarly sized OLED display with a ratio of approximately 19.5:9, just like the current iPhone X, but the diagonal size of this screen can be increased to 6.5. Inches, while the iPhone X has a screen size of only 5.8 inches.
The larger screen also means that the iPhone Xs Max's body will not be as "small" as the iPhone X, but according to the leaked information, it is not impossible to master the iPhone Xs Max. According to the well-known newsman @OnLeaks, the actual size of the iPhone Xs Max is 157.5×77.4×7.7 mm, which is much higher than the iPhone X in the height and width of the body (iPhone X is 143.6×70.9×7.7 mm), but slightly Less than the iPhone 8 Plus. You know, the iPhone 8 Plus with a 5.5-inch display measures 158.4 x 78.1 x 7.5 mm.
Are you can not wait to buy a new iPhone XS/iPhone XS Max to replace your old iPhone? If so, you must be interested in how to transfer data from iPhone to iPhone XS(Max), right? Well, take it easy, what you need is just the Mobile Transfer.
Mobile Transfer is the outstanding data transer program which can transfer photos, contacts, music, videos, calendars, call logs, messages, apps and app data for you. It supports iPhone, Android Phone, Blackberry, Nokia, Windows Phone perfectly. With it, you can copy data from one phone to another without any difficulty. Besides, you can backup and restore your iPhone data by using this tool.
Related: Transfer Data from Samsung to iPhone XS/Max
Mans1950
Have you ever imagined to transfer data from one iPhone to another without using iTunes or iCloud, cause iTunes/iCloud restore will overwrite the previous data on your device? In such a situation, PR iOS Backup & Restore is exactly what you need. It allows you to transfer selected data from iPhone to iPhone in a few clicks.
How to Transfer Messages from iPhone to iPhone Without iCloud
How to Transfer Contacts from iPhone to iPhone Without iCloud: 4 Tips
