How to transfer data to iPhone X/8/8 Plus
Alenliu
Yes, we can pre-order iPhone X/8/8 Plus on 9.15. After we get them, you may have some important data, like contacts, messages, photos, videos, etc to transfer from computer or old phone to the new iPhone X/8/8 Plus. Do you think it's difficult or not? Let me tell you, it's easy. Just follow the steps below, you can do that.
Part 1. 2 Steps to Transfer Data from Computer to iPhone X/8
Only two steps is needed, and you can easily transfer the contents from computer to your iPhone X or iPhone 8 with the help of the professional tool - Computer to iOS Data Transfer. With it, you can transfer the files that even iTunes does not support to transfer, and also you are allowed to select the content you want to sync with your iPhone, including the playlists, photos, books, contacts, SMS (Text messages) and etc.
Here is how:
Step 1. Link iPhone to computer
First of all, please connect your iPhone to your PC and then launch the installed software on computer. The software will automatically detect the files on your iPhone, and show in different categories.
Step 2. Begin to transfer data from computer to iPhone 8/X
Then you can enter different file tab and find the "Add" option to transfer files from computer to iPhone.
For example, you can sync songs from computer to iPhone 8 or iPhone X by visiting the Media tab and hit the Add option to select the music files from your computer, then confirm your action. Thus all the selected songs will be transferred immediately from computer to your iPhone 8 or iPhone X.
Part 2. 2 Steps to Transfer Data from Old Phone to iPhone X/8
Want to transfer contents from an old phone to iPhone X or iPhone 8? It is very simple, too. Only 3 steps is needed, you can easily transfer files from previous smart phone to iPhone X or iPhone 8. With the professional tool - Mobile Phone Transfer tool, you can not only transfer contents from Android device to iPhone, but also you are able to transfer data from iOS, BlackBerry, Symbian device to iPhone 8 or iPhone X freely. And different file types are supported by the software, such as the photos, calendars, contacts, messages, notes and etc.
Here is how:
Step 1. Connect both of your iPhone X/8 and old phone to compute
r
After installing the software on your computer, please link your iPhone and the previous phone to PC with two USB cords. Then run the program, visit the "Phone to Phone Transfer" option on the interface.
Step 2. Choose the desired file types to start transferring
Then all the files on your phone will be shown in different categories, just check the file type tab to select the contents and then click the "Start Transfer" option to begin to immediately sync the selected data from an old phone to iPhone 8 or iPhone X.
For example, mark the "Contacts" tab and click the "Start Transfer" button to begin the transferring process.
Note: Please ensure that iPhone X or iPhone 8 should be placed on the Destination side. If not, just hit the "Flip" option to change the position.
Tmzmo623
Phone Transfer is the all-in-one yet easy-to-use data transfer tool that can directly Transfer Music, Contacts, Photos, Videos, Messages, Calendars, Apps and other files from one mobile phone to another. So, you can one click to transfer data from iPhone to iPhone X by using this tool.
Saraling White
Thanks all for tell me to convert digital content to iPhone with ease. It's really useful for me.
