Renkang
Once you look at the Lenovo Z5 Pro GT, it won't be so easy to forget. First you may notice that the Z5 Pro GT has almost no borders. This is because, like Oppo Find X and the previous Vivo Nex S, the Z5 Pro GT is a slider phone. The front camera and handset are hidden inside the phone and pop up automatically when needed. In addition, the phone is similar in appearance to the Lenovo Z5 Pro - except for the red color around the frame and the carbon fiber pattern on the back of the glass.
Inside is the place where the Lenovo Z5 Pro GT really set some records. The Z5 Pro GT is likely to be one of the world's first mobile phones equipped with the Opteron 855 processor with one plus 7, which should make it a top-of-the-line phone. However, other data has also set a record, such as the Z5 Pro GT package in 12GB of RAM. This is the largest memory I have ever seen on a smartphone. It also has 512GB of memory.
Can't you wait to buy a new Lenovo Z5 Pro to replace your old Android phone? If so, you must be interested in how to transfer photos from Android to Lenovo Z5 Pro, right? Well, to transfer data from phone to phone, what you need is just the Phone to Phone Transfer tool.
Phone to Phone Transfer can transfer files from one Phone to another phone with 1 click. It can transfer photos, contacts, music, videos, calendars, call logs, messages, apps and app data for you. It supports iPhone, Android Phone, Blackberry, Nokia, Windows Phone perfectly. With it, you can copy data from one phone to another without any difficulty.
Related: Recover Data from Lenovo Z5 Pro
Alenliu
The good choice to Transfer Photos from Android to Lenovo Z5 Pro is using Phone Transfer tool. After linking both of them to computer via usb cable or wifi, the Phone Transfer tool will scan out all data on them, including photos. Then you can transfer them directly.
