How to Transfer Photos from Samsung to Huawei Mate 20X?
Tmzmo623
In terms of daily use experience, we mainly investigate the fluency of HUAWEI Mate 20 X system operation and App usage. The test method is to adjust the GPU rendering mode analysis to “display as bar graph on the screen” in the developer option. A reference for fluency.
The first is the fluency of the basic operation of the system, sliding back and forth on the EMUI 9.0 main screen interface, the fluency is very high, and when sliding to the left for a moment, you can see a short and slight drop frame, because A negative screen needs to suddenly load rich multimedia content including video, text and pictures, and it is normal to have a short drop frame.
Are you wanting to buy a new Huawei Mate 20X to replace your old Samsung Galaxy phone? Apparently, many old Samsung Galaxy users have made this choice. However, how to transfer Samsung photos to Huawei Mate 20X when you get this new phone?
To sync all data from the old Samsung phone to Huawei Mate 20/Mate 20 Pro, what you need is just the Mobile Transfer. Mobile Transfer can connect two phones at the same time and transfer files from one phone to another. You can transfer contacts, music, photos, videos, messages, messages, call logs, calendars, Apps and App data from one phone to another.
Related: Transfer Samsung Photos to Huawei Mate 20/Pro
Alenliu
Samsung to Huawei Transfer tool can help us Transfer Photos from Samsung to Huawei Mate 20X on pc, if you have both of them in hands. You just need to connect them to pc via usb cables, start the tool. A short time scanning later, you can directly transfer photos between them.
Salinamati
When we transfer from Samsung to Huawei , we need transfer data from Samsung to Huawei. It's easy now to transfer photos from Samsung to Huawei with Eelphone Mobile Transfer, connect two phones to computer, and allow USB debugging in your two phones. Then you can select the data type from Samsung to Huawei, select Photos to migrate from Samsung to Huawei.
